  • Replies 113
can u do a black one that has the letters black during the day (not clear).
I'm only interested if this is possible.
Yes i think im sure I can make it happen. specify you paint code and the colour of lights your after. Pm me
Hi Mate,
very intertested in one
Ive got S2 Silver/Pewter Colour whatever they call it, would want the red light and posible the non clear words like i have atm, but would i lose brightness with not using the clear writing?
Thanks get back to me
Hi Mate,
You loose a little bit of brightness but I wouldnt stress too much about it. The one in silver in the original post is a stealth light up and its still bright as.
PM Sent.
PM replied
Did you put the red light up fascia on your car yet? I wanna see! :thumbsup:
Nah mate I am still cruzzin with a wite light up. If you go back to page 1 or 2 you will see soe red ones which were done.
Ok guys, after playing making a few of these, I have to say that the 'stealth mode' (non clear letters) can only really be possible if your after white lighting, doing this with red lighting doesnt bring the best results.
Will have pics tonight of some finished white garnishes...
Ok heres a few pics of white garnishes pretty much finished with red lighting take note of how the letters look when the light is off. These photos do not do them justice!
Sorry about the huge image sizes!
PS Baconer and Titan these are yours!
FANCY! top quality work.
If i were to supply you with an R31 rear garnish - would you be able to create one using that? - just the bit in the pics with the writing ;)
Edited by B. J.
Nice!!
Was going to call you today but lost your number and didnt get back from work till late so could you pm me your number and ill call you some time around 5pm tommorrow
Edited by Baconer
Just a thought mate, but why dont you set up a g/b for these?
Hi, if you, or anybody else are interested in one of these please PM me and you can order one that way.
Thanks
Nick
If i were to supply you with an R31 rear garnish - would you be able to create one using that? - just the bit in the pics with the writing :nyaanyaa:
Sorry mate only for R33's, looking into doing Silvias
  • 3 weeks later...
Can you do stealth ones in black with that spray on tint stuff?? I want one of these for my S2 but dont want the red during the day, if its close to taillight brightness it will be ok
Received mine on Friday, installed it over the weekend and i am quite impressed with the results.
Thanks to tuktuk for the picture.
Awesome glad you like it mate. Hope the instructions helped out
Anything stealth is impossible with red lights, they arnt as strong as the white. I might be able to do the black ones with white lights in the stealth...
I think the red letters would look nice on a black car. would match your tail lights when turned off. Your call though.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
