I've narrowed it down to a few choices only....basically i want as much response as i can get from my rb25det, and would like to know which turbo would suit for a street r33....i would like to make a car with enough power to pass a high 12 pass on the 1/4 aswell......maybe 250rwkw will get me there???.....please help guys, heres my 3 major considerations atm:
HKS GT-RS
GT-SS
GT2530
current mods:
fmic
apexi pod
3" exhaust + split dump
bosch 040 fuel pump
splitfire coils
the threads i see about the gt-rs are generally for the rb26 motors, and they say its too laggy for them.....but it seems they are quite a good turbo for the rb25? why is that?
thanks!
Edited by nsta
  • Replies 46
thanks!
This is because the GT-R's that say the GT-RS is too laggy are running 2 GT-RS' turbo's.
One GT-RS would be fine on an rb25.
A gt2530 is a good responsive turbo... if you're running 2 of them on a GT-R lol. But really, this seems way too small for an RB25 single.
GT-SS is again just a little too small.
My vote is GT-RS or GT2871R.
Good luck!
gtrs is a an awesome turbo, but if your looking at turbos that size of what you suggested i would seriously consider a slide highflow, they are awesome for the price and bolt back on with minimum mods. i put one on a mates car and it took me under a day including stocker removal and the thing hauls
I have driven a 33 with gcg hi-flow, and responce was pretty good actually.. full boost by 3.5-4, which ok is a little laggy.. But god damn does it pull!!
hi-flow might be cheaper than gtrs as well..
thanks!, whats the response like of a gtrs?compared to say the stock turbo, which is really reponsive down low.....and will it get me to 250rwkw?, and a high 12 sec pasS on the 1/4?this is my long term goal, and one i dont want to keep changing turbos around for....also how long will an rb25det engine last with a gtrs and that amount of power?
You don't need the MAGICAL 250RWKW POWER to run a high 12 second pass, i've got around 220-225rwkw and ran 12.9 on 225/50/r16 Toyo T1R's @32psi tyre pressure
GT-RS or HKS2535 or a GCG/Slide Highflow would be my choice
You will also need:
-Bigger Injectors
-EBC Boost Controller or bleed valve
-Remapped ECU /Powerfc or the like.
You will also need:
-Bigger Injectors
thanks for that, yeh what size injectors would suit?and is it bad to get bigger than you need injectors???, cause the ones im after....theres no real difference in price between nismo 550cc and 700cc injectors....so should i get the 700cc ones instead?. I have a sau bleed valve, dnno if that will be sufficient, but seems to hold boost quite well:)
and im after a power fc aswell, will i need the hand controller or not?
cheers,
cheers,
for the power you are after, 550 cc injectors are plenty. if you want even more power down the track then you might want to get the 700, but if not, youll be just wasting fuel. If you bleed valve is up to the task then what you have is fine. you will need a good ecu to control eveything and the power fc is ideal and best to get a handcontroller so that you can monitor knock levels, adjust timing if necessary, etc..
Best turbo to do a high 12 pass and the most responsive would be the stock turbo. It has been done numerous times.
Some of the turbos that the guys mentioned above would be way too big and be lag monsters. e.g. the 2540? lag central.
umm a 2540 is just a touch bigger than a 2535 and smaller than a 2835 and GTRS, so how would it be a lag monster??
yeah stock turbo hi flowed would prob be the best....but if faster 1/4 time would prob invest in drag tyres...from my experience a set of 2nd hand drag tyres will take 0.3-0.4 off ur time.....to do that with just power increase ur looking at like 30-40kw...
I've got a GT3071. Pumps 15psi and over 230kw atw by 3200rpm. Stock injectors and air flow meter. Turbo cost $1500 plus oil\water lines and intake mods. All up cost $2000. Is sweet, loves to peel the rubber off by 10 psi
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
