car should be at QR inthe morning tomorrow!! for a bit of a shakedown, testing dry sump and breather setup, cooling system etc.
Awesome, i'll be out for sprints in the arvo so i'll make sure i get there nice and early to see your runs :blink:
Giant, sorry I could not come to QR early enough to see your car. How did you go? Is there any chance that you could post some pics of the lexan windows? I think I need give my skyline the Jenny Craig diet :)
hey guys
for an update!
went out saturday morning to do a test. did about 15 laps maybe 18? ( in 3 sets)
intial test! result excellent!!!
dry sump test - perfect
cooling system, oil and coolant- perfect
doors and windows didnt flap around
cage result - really feel the chassis stiffness
testing at about 85 percent on re55 hards, mark did a 1.17:5 on the national which beats our previous best of 1.17:9
very promising on soft semi's at 100percent should put us into the 1.16 bracket wven there werent other mods.
next to test is
ohlins coilovers (due this week)
4 inch side pipe :laugh: (already made)
different injectors (ready to go)
soft compound rubber (due now)
will keep you posted and some more pics soon.
cheers russ
p.s we did have an oil leak (helps to put the dipstick in or plug the tube/hole!!)
i was there and saw the 32 go round...it is damn fast and its not even finished yet. The japs wont know what hit them.
While russ and mark had a good run, we blew a turbo the same morning :) Seems a perishing rubber line that supplies oil somewhere had bits building up in the turbo oil feed, blocked the hole and ceased the turbo.
P.S I love the doors russ, so light. Im telling ya mate, full slicks. Try a few runs on a set, you will wet yourself with the amount of traction you will get over the hard semis.
Latest pics of my rally car from this weekend...
7 fence posts at 130km/h
Damage report:
Bent right rear suspension, looks like just the lower rear suspension arm
The scratch (and small dent) on the rear guard
Missing fuel filler cap (somewhere in a padock)
Missing rear window (also spread across the paddock)
Squashed fuel tank - surprised it's not leaking actually
Bent wheel
Broken headlight
7 fence posts (One thrown 15m into the paddock where the glass and petrol cap are)
Bet you didn't lift off though?
Kept the foot in it the whole way, until it started heading for the bank, then I gave up and applied the brakes. Just needed more steering lock! Strong old things tho, once untangled I drove it out of the stage.
Damage report:
Bent wheel
Broken headlight
hehe!!
thats the shit right there!!
130 clicks hitting fence posts and the foot still buried!
love ya work!!
cheers russ
Hey screamin' - I found out last week the Dutton Rally is having a round in N.Z. next year. We are currently planning on getting over there for it. Hopefully we can see a few local based Skylines for the event as well.
BTW Russ - no round in QLD next year. So you guys will have to come to Vic (or N.Z.!)
ahh damn it!! means i dont get a cheaper round.
might have to come to vic to play!! :yucky:
They are stepping up the Dutton events next year Russ. Some of the stuff should be tops. :yucky:
Also - I've pretty much convinced Mossy to bring back the free entry for reigning champs so you should at least get free entry to NSW next year. :)
Good man!
Hey sounds good. Dutton is a tarmac rally similar to a Targa isn't it? We've only got a handfull of guys running Skylines in that spec here. Most guys with money run the GT3's.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
