yeah you want the car on the ground to check alignment. up on stands is no good. obviously you can jack it up to adjust, but must be on flat ground again to re-check.
oh yeah for sure. what i'm getting at is if you would need to roll back (e.g. 10m) then roll forward to allow all the tyres/suspension to 'seat' then check again. right?
How about using a simple clinometer for camber measurement? Autospeed states the ones picture cost $15 from a marine store, you could bolt it to a length along the side and just rest it against your wheel (maybe with a right angle at the bottom to sit it on the ground).
Hows it go on the race track lauren, ours sucks (although we snuck home 3rd behind 2 race cars at the road event the other day). too much understeer
Its fun at motorkhanas though..... http://www.hgeconsulting.com.au/khanazed.wmv
I actually find it a struggle on the tighter motorkhana courses (although you seem to make it look effortless) but the more open courses I seem do quite well in. I've only been participating in motorkhana and circuit for last three months so i still have a LOT to learn. It's a bit of fun anyway it wouldnt be a car i would use if i wanted to be ultra competitive no haha.
Oran Park. 2 sprint races on the sat, and a sprint and a 1hr enduro on the sunday.....hopefully we can last an hour on a tank of fuel this time, last time we had to retired about 4 min from the end
Go the open fuel filler :cool:
paint job looks shmiko on the track, and that balaclarva makes you look very stig like.
Yer just noticed that as well, need to get that looked at. That corner although its doesnt look like it it has about 18 degree of banking have not seen a pic of that corner before, little surprised that the suspension is compressed that far.
heres mine!
spec wise: its got the normal gear power wise 350hp @ 16psi, i've been more focus on suspension and brakes ---> 90% of my suspension arm have been replace with nismo items, got nismo swaybar F&R, aftermarket tierods and castor rods, current has d2 coilovers but waiting for my TEIN RA-spec to arrived (damper and rebound adjustable with 10kg spring rate F&R)... my clutch has just failed so twin plate is on the way, ohh yeah running ap caliper up the front with larger disc.
im pretty much happy with the car atm, just need an lsd and it will be perfect
nothing too special atm, as it was a daily driver but i have since got a nice daily which cost me $20 a week in fuel :thumbsup: so its getting the full track treatment in the near future... cage, stripped inside etc etc
Edited by [Michael]
Ok, so it's not mine, but Jason the owner and I built it, and I get to sit in the silly side :/ No pics of the engine out/suspension etc unfortunately. It's just built to CAMS Tarmac specs. But we wanted a stereo and the aircon still :D
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
