Suspension wise i would be clueless as well. But as they are commonly used for a bit of drift both in the US and in Japan you should be able to find a reasonable amount of info, particularly for the front end.
Why webers?
Suspension wise I am not to sure... More research will need to be done!
use custom compact weld on sleeves.
http://www.ae86drivingclub.com.au/forums/s...ead.php?p=75969
dunoo, will have to ask him. Maybe google the name above the door if you can make it out.
also, bought this from Revzone in melb.
replacement rear half should be arriving at the shop next week. rebuild imminent. tempted to chuck an SR in it for shits n giggles :P
Looks like Trevor Voss' old car, was a nasty wack at Dandenong Rd corner at Sandown...
Cut & shut FTW!! :teehee:
just cut the fkn thing off and put a long rear on it....its stuffed you dont need no underbody measurement for that :teehee:
well we've bought a long rear and waiting for it to get to the shop. altho I'm hoping the driver side rear quarter is salvageable.
Why webers?
Well its that or dellorto's or scoring a 20V on the cheap...
My reasoning seems to be based around nostalgia and noise more than anything - call me indulgent :teehee: .
In terms of size, my carb tuner recommended 40's if its a daily and 45's if its seeing race and high rpm use. Expected outcome will be doughy down low (he said from 2500 rpm and below) but above that it should be peachy with excellent high RPM response.
He seems to believe with the cams I am looking at it will all come together nicely.
Just an idea of what they sound like with carbs for those who don't know:
http://www.youtube.com/watch?v=HrXMSCRHwug...feature=related
except benms lone nascup car which of course was US built or at least designed.
Designed and built in USA more than 10yrs ago (with minor updates done to chassis and new shell designs over the past 10yrs).
I'd much much rather be in an accident or rollover in my nascup (baby grand mmra) car than in the current Aussie Racing Cars due to the chassis/cage design. But then, i'd much much rather own an Aussie Racing Car than my Nascup car but not for the extra $20k purchase price.
I think the suspension plans for my car are thrown out the window.
I am kind of sticking to improved production guidelines because if I ever got serious thats the path I would take. It seems that I am unable to change the rear suspension to a type other than stock apart from the obvious springs / shocks and so on.
Exerpt from rules:
9. SUSPENSION AND STERING
9.1 Springs: Springs are free provided that the type and location are unchanged (by type is meant: coil, torsion bar,
leaf etc.)
Am I correct in thinking that I would be unable to change to weld in coilovers?
Weld in coilover suspension for the rear. Essentially changes strut suspension to coilovers. Erm its easier for me to link the product:
http://www.fullboost.com.au/forum/showthread.php?p=42402
KE70's have a five link rear end stock.
So changed the springs to 6kg - I had harder springs in for a little while but I found it made the rear even MORE tail happy when I just want something fairly neutral with perhaps a touch of oversteer. New adjustable shocks. New canard bar. New heavy duty Whiteline sway bar and strut bar coming. Lots of polyeurethane bushings. Also scored some free power - removed everything in the boot, rear seats, some sound deadener and most of the centre console. Enough to be an advantage but no so much that I would be uncomfortable as I am driving it on the street a lot of the time still.
Hell it weighs 940 kilos stock (or there abouts) anyhow :thumbsup:
repost all the pics of your car dane! forum lost our posts. :D
anyway, carrying on from our now invisible conversation I went out and got one of those green tomei 3 point braces for the S13. I'm not impulsive :)
was not too bad on price, and will be here today. schweet.
haha! awesome work, i paid nearly $300 (incl ems) and had to wait a month for one to come up on yahoo jp, you were very quick!
i actually noticed a positive difference in the front end "feel" of the car when i swapped out the old cusco and installed the tomei.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
