Suspension wise i would be clueless as well. But as they are commonly used for a bit of drift both in the US and in Japan you should be able to find a reasonable amount of info, particularly for the front end.
Why webers?
Suspension wise I am not to sure... More research will need to be done!
use custom compact weld on sleeves.
http://www.ae86drivingclub.com.au/forums/s...ead.php?p=75969
dunoo, will have to ask him. Maybe google the name above the door if you can make it out.
also, bought this from Revzone in melb.
replacement rear half should be arriving at the shop next week. rebuild imminent. tempted to chuck an SR in it for shits n giggles :P
Looks like Trevor Voss' old car, was a nasty wack at Dandenong Rd corner at Sandown...
Cut & shut FTW!! :teehee:
just cut the fkn thing off and put a long rear on it....its stuffed you dont need no underbody measurement for that :teehee:
well we've bought a long rear and waiting for it to get to the shop. altho I'm hoping the driver side rear quarter is salvageable.
Why webers?
Well its that or dellorto's or scoring a 20V on the cheap...
My reasoning seems to be based around nostalgia and noise more than anything - call me indulgent :teehee: .
In terms of size, my carb tuner recommended 40's if its a daily and 45's if its seeing race and high rpm use. Expected outcome will be doughy down low (he said from 2500 rpm and below) but above that it should be peachy with excellent high RPM response.
He seems to believe with the cams I am looking at it will all come together nicely.
Just an idea of what they sound like with carbs for those who don't know:
http://www.youtube.com/watch?v=HrXMSCRHwug...feature=related
except benms lone nascup car which of course was US built or at least designed.
Designed and built in USA more than 10yrs ago (with minor updates done to chassis and new shell designs over the past 10yrs).
I'd much much rather be in an accident or rollover in my nascup (baby grand mmra) car than in the current Aussie Racing Cars due to the chassis/cage design. But then, i'd much much rather own an Aussie Racing Car than my Nascup car but not for the extra $20k purchase price.
I think the suspension plans for my car are thrown out the window.
I am kind of sticking to improved production guidelines because if I ever got serious thats the path I would take. It seems that I am unable to change the rear suspension to a type other than stock apart from the obvious springs / shocks and so on.
Exerpt from rules:
9. SUSPENSION AND STERING
9.1 Springs: Springs are free provided that the type and location are unchanged (by type is meant: coil, torsion bar,
leaf etc.)
Am I correct in thinking that I would be unable to change to weld in coilovers?
Weld in coilover suspension for the rear. Essentially changes strut suspension to coilovers. Erm its easier for me to link the product:
http://www.fullboost.com.au/forum/showthread.php?p=42402
KE70's have a five link rear end stock.
So changed the springs to 6kg - I had harder springs in for a little while but I found it made the rear even MORE tail happy when I just want something fairly neutral with perhaps a touch of oversteer. New adjustable shocks. New canard bar. New heavy duty Whiteline sway bar and strut bar coming. Lots of polyeurethane bushings. Also scored some free power - removed everything in the boot, rear seats, some sound deadener and most of the centre console. Enough to be an advantage but no so much that I would be uncomfortable as I am driving it on the street a lot of the time still.
Hell it weighs 940 kilos stock (or there abouts) anyhow :thumbsup:
repost all the pics of your car dane! forum lost our posts. :D
anyway, carrying on from our now invisible conversation I went out and got one of those green tomei 3 point braces for the S13. I'm not impulsive :)
was not too bad on price, and will be here today. schweet.
haha! awesome work, i paid nearly $300 (incl ems) and had to wait a month for one to come up on yahoo jp, you were very quick!
i actually noticed a positive difference in the front end "feel" of the car when i swapped out the old cusco and installed the tomei.
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
