Heres my ongoing RB31/26DETT build, planning to give it a toss about at some more or less local tracks :blink:
RB31DETT! Thats my project !
Here's the latest of my RB31. The engine is on a test rig and is ready to fire up. With the exception that I need to put dump pipes and an exhaust on it, and dynabolt the rig to the floor. Hopefully not longer than 2 weeks till I get that sorted out.
cool rig mate. :cool: looks good. are you going to run some kind of flywheel brake? and I guess you will be plumbing up the intake side with an intercooler as well?
should be fun running it on the rig. :)
Thanks Richard. I'd love to have a water brake to hang off the back of the rig, but its just not practical for what im doing at this stage. The main purpose of the rig is to run the engine till hot a few times and confirm that I dont get cross fluid contamination between the oil and water, or any leaks... ie that my spacer plate and gasket systems work properly. Once that is proven I can bolt it in the car and start having some fun tuning it. Im not woried about the sleeve or head gasket setup at all. Im very confident that will about 900hp reliably before the top end is anywhere near letting go.
The ecu is an old V400 wolf running map sensing, 3 bank injection and waste spark ignition. Ive setup the rig so it can start R32/3 or R34 engines. I'll just be putting a filter over the intake to the plenum and thats it. The engine is currently all taped/sealed up still.
The project has taken way too long to get to this stage. I had some hold ups when I bought a house recently and then accidently caught the renovating bug. Im back in the shed playing with engines again now though. I have a closed deck 2.8 and another open deck 3.2 in the works as well.... too many projects.
The car's still going great too. Scored some 18x10 TE37's and semi slicks for it recently too. I'll be competing in a few sprint series's this year and intend on being competetive against the evo's. Will post some update pics of that soon.
Cheers!
Ian,
Are these engines you are designing and putting together using standard modified (re-ground) cranks?
The one above uses a modified RB30 crank, with the rod journels offset ground and widened to SR20DET dimensions, and slotted to clear the oil squirters, plus it has the usual standard mods. Jun pump drive, drilled and grub screwed oil galleries, precision balance, etc. This engine is 87x87=3104cc, and the same rod/stroke ratio as an SR20. Its possible to go a little larger on the stroke, but you start getting rod to sleeve interference issues past about 88mm.
Here's a couple more pics of the other project again. Yes its a VW so I hope you all dont get sick! :blink: I finally got the engine started last weekend too. Its been nearly 3 years ive had the car off the road, and virtually every part of the car is custom now Most people can't spot the standard parts. There is about 8 of them! Entirely custom chassis, porsche 968 brakes and suspsension, 930 tranny, 4 stage dry sump system, and a custom VW "oxy boxer" based 2.5lt twin turbo'd (8cm T517z's). My dream now blows flames!
hell yeah... that's a work of art, love it
there's a show on cable at the moment called Beetle Crisis... all about modified and restored Beetles etc... but yours is by far the coolest I've seen!
I've got those turbos on my GTR, can't imagine how mental they would be on a lightweight, RWD beetle racer!
Looks like a well sorted R33 . Go give it a trash and post up some vids :(
here you go roy
its very laggy... but seeing as im running my old tune which was a completely different turbo it isn't too bad. spent the most of the night fine tuning the suspension and was pretty happy with it by the end of the night, only problem was my brake pads was completely gone so i was taken it easy and not braking too hard.
Edited by Kaido_RR
Here's a couple more pics of the other project again. Yes its a VW so I hope you all dont get sick! :banana: I finally got the engine started last weekend too. Its been nearly 3 years ive had the car off the road, and virtually every part of the car is custom now Most people can't spot the standard parts. There is about 8 of them! Entirely custom chassis, porsche 968 brakes and suspsension, 930 tranny, 4 stage dry sump system, and a custom VW "oxy boxer" based 2.5lt twin turbo'd (8cm T517z's). My dream now blows flames!
Thought you may like this: http://speedhunters.com/archive/2010/01/13...vw-1303-rs.aspx
boys this is my new race machine
me and my dad built it, not finished quite yet but will be finished with in the mouth.
and that's it for now
hope you guys like
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
