well, it isn't a skyline or even skyline powered but this is the new climb beast.
picked it up from my boss last week
-space frame chassis
-k series corolla motor
-twin side draft webers
-morris minor diff with full floating axles
-full rose jointed suspension
Edited by gsr600guy
jeebus! pics of the frame and suspension with clothes off thanks!
just pulled all of the brake cylinders and callipers off of the car to have rebuilt- it's been sitting around for a while- if its sunny outside tomoorrow i'll get some and post them up.
but for now here's the motor before it got a decent clean
and a pic of her when i picked it up
Thats awesome
may i ask how much it set up back?
car is on loan from my boss. the deal is that if i pay for consumables - ie fuel and tyres- and keep up basic maintenence, then i get to use it for free. it has been sitting around for a few years so the first thing is to go thru the whole car and make sure it's all safe and CAMS approved.
hopefully it'll be competing in hill climbs later this year.
cool car! you will need some good biceps with the slicks up font and the tiny go kart steering wheel!
should be wicked fun and sound great with the big webbers on it.
I wish I could score a deal like that.
But what happens if you bend it?
funnily enough that was never discussed. i'm speaking to roll cage fabricators at the moment to try and get some extra strength put in around the driver for safety.
hopefully the steering isn't too heavy- the car weighs stuff all- but i am thinking of putting a larger diameter wheel, mounted further back for better ergonomics.
next time i have it running i'll record the noise it makes. sounds Fkn wicked, little flames out the pipes on overrun at times too.
Well i was waiting to put the new TE37s on it and the new engine bits before posting pic but who knows when that will be...so
not sure how i missed this-
your car looks amazing!
such a cool r32, with loads of history too.
and the wing is very cool, everything about it looks mint, and in my opinion it will look better sitting on some wide 17's.
keep it up!
Cheers! Have some 17" TE37s (9.5" R and 9" front) in satin black with some metallic grey flake or something through it. They will be going on when the car gets back from the mechanics in a month or so. (Brakes, manifolds, exhaust, tune etc)
If a few things go my way then the car will be doing some pretty cool and special things later this year...otherwise it will just be sitting in storage whilst I am away :)
What size wheels are they, i would hurt people for the right sized Regas for my car :D
17x8 +35 fronts with 25mm spacer
17x9 +18 rears
I didn't even know what they were when I bought the car. I was worried they might be a bit dodgy when I saw "Made in Russia" stamped into the back of them! lol
posting this in here because I know you're all motorsport tragics, and are seemingly not biased to one make or model,
a friend emailed the link to me, he didn't have an explanation as to why pickles have all of this available at once, but some very nice gear none the less!!!!!
edit: it appears they are having their muscle car auction...
http://www.pickles.com.au/cars/listing/LIS...aleid-103001773
namely the vs gts-r serial number 001 with 79kms on it!
also the HRT 427...
the walkinshaw, and turbo XE... the list goes on!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
