Team Wang Vs Btr - Long Sleeve Shirts - Aug Deca
OK Ladies,
Ive been chatting with Corrinne (D_I_F) from Team NSW and she has kindly offered to organise long sleeve shirts for this upcoming DECA in August.
The design is as follows:
Vic Version:
The above design is a rough layout - final desing/logo sizes, etc will be posted by Corinne shortly.
Sizes are expected to range from S - XXXL.
Costs will depend on number of shirts ordered.
We hope to be able to have something like NSW in black and VIC in white, but need to hear back from printer.
Corrine will post more info as it comes to hand.
But for now.....who's interested???
TO ORDER - you will need to send Corrine (D_I_F) a PM to confirm order.
Cheers
BEC
  • Replies 46
Maybe on your guys vic ones you could have "its not the size of the logo that counts... its all in the timing of the WANG" or "power of the WANG"
or something equally as silly... that BTR thing is HUGE... obviously compensating for something
Yea sorry guys, I'm going to have the BTR logo resized so it doesn't oversize the wang.. :laughing-smiley-014:
So Yea, Any questions please pm me :(
Ok I've got a costing for the shit's they work out to be about $43 each.. The most expensive part of the cost is the set up fee's for the front side of the shirts..
I'm going to see what I can do to reduce these costs..
Im down for a NSW one. Only can i ask that we make the front left pocket area say SAU NSW, in a smaller size say 6-8 cm wide, then on the back have the large print that you show on the front? Also lose the Team BTR, should just be "BTR Beer Talk Racing"
Also, need to get approval from Boosted Zed, PORTS and Beer Baron before running off with their Track slogan... :)
Also before placing an order let me know where to email the verctor art image of the wang logo.
We don't want our wang's to be in poor quality now do we?
Also in! ... I like the small SAU logo idea from Bris (First and only time I will ever agree with him on the forums)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
