Spotted another Veyron today, baby blue on silver. Also more ferrari's than you can poke a stick at, then there was the Conti's, porches and SLR Merc's. Anyone care to guess which city/Kingdom i am in at the moment???
I'll put some pic's up when i get them off the camera.
Jeff we timed 2 laps - did a 1.50.0 and a 1.50.2. Apparently Christian Murchisan did a high 1.48 earlier in the week.
Not bad for a production car on street rubber (Pirelli P Zero). I sure as hell was impressed. Not to mention I did 40 laps in 2hrs and the car was still perfect at the end (brakes fine, water 90degs and oil 100degs)
FYI Christian did some hot laps in the RS4 which we timed at 1.55.2 - so the R8 is considerably quicker.
That's awesome isn't it? This newer generation of cars are really eclipsing the previous generation.
saw a black c63.. plates were 19 or 16
in camberwell it tore past me.. that engine actually made me semi errect. was good to say someone buying one of those n using that car to its potential.
Ah... nope. There's a few now.
You should retract that statement before you are forced to eat your (vegetarian) hat...
http://www.skylinesaustralia.com/forums/in...=178021&hl=
LOL @ Vegetarian Hat :laughing-smiley-014:
Seems my eye for one colour Veyron's let me down this time though :wave:
it's my boss, the plates are 19, i think there for sale with all his other plates
I feel so depressed again, have seen so many Maseratis, a few 599 Ferraris or a few of them may have been 612s?!?! Saw a shitty R35 that was going farking fast and loudly and proudly down the road. A few M6s...like i said, its depressing looking at all these big dollar cars being driven by blokes younger then me, And very few of them are ex-pats :wave:
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
