  • 3 months later...
Have used this guide to fit a Greddy Plenum to a RB25det Neo in my R32Gtst.--works a treat
All is very similar but you will need to make an adaptor place to fit the Neo AAC/cold start valve.
Also the R32 Clutch master will need to be changed over to a R33 S2 unit as the R32 Clutch cylinder sticks out too far. The R33 S2 unit has a bit more inside the car than the R32 unit hence why it seems shorter when viewed on Firewall.
Used a R33 S2 throttlebody also.
I have used the top feed injectors off the neo also & a twinfeed fuel rail so new brackets had to be fabricated-used Aluminum 3mm angle which worked a treat too. Holes are offset but everything is Rock solid with no movement.
Cheers ix9, matey you rock-this is 1 hell of a thread & 6-7yrs after the time you did it its still helping people like me
Todd
  • Like 1
im going to do this install this coming weekend and went searching for another how to with photos in it. stumbled across this http://rb26.net/index.php/guides/3-installing-a-greddy-style-plenum-into-a-rb25det which appears to be exactly the same as this one
  • 1 month later...
  • 3 months later...
Would it really give 40% better throttle response? seems to contradict the view of the stock runners being best for response then.
I seriously doubt it.
Stock runners are best for torque.
  • 5 months later...
  • 1 month later...
Get a adaptor plate and put the original throttle body back on. Not going to make a huge difference going to a 80 or 90mm tb. Plus you also have better throttle control down low with the std
