Holy farken... that is sexual andy!
was quite funny, a really young girl around 18 was driving..with a really old guy looking very worried in the passenger seat, probably her dad....or sugar daddy, what ever the deal was I hope it was worth it for him cause he looked like he was about to cry every time she rode the clutch off the line!
spotted a f430 at liverpool on the weekend.....damn hot
I almost forgot, I spotted a new Black Lambo on the old pac Hwy on sunday arvo on my way back from some twisties..
Useless without pics
WTF-33R Im assuming you're working at Trivett? They look like the shirts they just brought in before I left. I saw and drove plenty of decent cars up there back in the day. I know what you mean when you say they don't excite you anymore. As much as I like "Supercars" the problem is you see one 996 Turbo, you've seen them all etc etc.
I use to work at Lambo and once you finish the first couple of days, it gets like any other job. Its almost worse because you have to take that extra attention to detail.
That would be correct
thats because trivett service centre is just off james ruse drive
i currently work at trivett and before that i work at rick damelian's and its so true the novelty wears off seeing all these cars and always being around these cars.. But if i ever see something different on the streets i have a mad druell..
Yeah which department? PM me if u dont want to say it in public.
Spotted one of the new Aston Martin Vantage Lagonda at the NSW championships on saturday.. I'm in loveeee...
Theres no lagonda in the name its just Aston Martin V8 Vantage. Seen that car came from the factory with Pirelli P-Zero Corsa semis!
And whilst im here
Spotted 2 Ferrari F430s today, as well as a 550 (I think).
2 430's and a 360 it was. all spyders.
did a favour for a friend yesterday and drove a wedding party around. hows this for a Line up of wedding cars
67 Mustang with a warm 302 (Brides parents). 70's Cadillac (bridesmaids), 2006 Lambo Murcielago (bride), 2007 GT3 RS (Groom) and 2005 Cayenne (Groomsmen) painted to match the RS.
Me with the exotics
Lambo
Cayenne S (my ride for the day. Really turns heads, especially cruising with the GT3 RS in tow)
GT3 RS
that lambo's front bar is probably worth more than my car................god damn self indulgent mofos...................yes i'm just jealous
and whats with the GREEN rs...............errrghhh......green????
Thats what I said when he ordered it.
But with the RS there were 3 colour options
Orange with Black Carrera RS badging
Black With Orange RS Badging
Green With Black
from what ive been told the Orange is tragic in person despite how nice it looks in magazines. He painted the Cayenne to match.
Also the uneven ground made the lambo look lower than it actually was.
Well next time ill have to have my camera attached to my dash im sorry, like i care enough to take pics of these cars as im driving....
Spotted this guy yesterday...
El Cheapo bastard decided to take the bumpy as f*ck longueville road then Delhi Rd onto the M2 instead of paying the $2.55 for the Lane Cove Tunnel :spank:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
