Hi ... I may have missed it but can anyone tell me where the TV Tuner is located in the M35 Stagea.
Hi Grant
The TV tuner is located on the left hand side of boot behind the trim. Just in front of the pocket on the left in the boot. You will need to remove the trim panels to get at it.
Cheers
Andy
Hi Grant
Cheers
Andy
Thanks
Grant
  • 1 month later...
Hi Frank,
Any chance of re-uploaing the images for us as it looks like some have gone walkies and i want to see a few bits that are missing?
Cheers
Laine
Hi mate:
I don't know, form does not allow me to edit to re upload the picture.
You can also go one step further when intergrating the ipod through the stereo. All you can buy in Australia is the 3.5mm headphone jack to RCA plugs. The problem with using these with the stereo is that the volume is controlled from the ipod.
One better is a cable that plugs in off the standard Ipod plug in the base that goes to RCA and will charge the ipod. I purchased mine from the US from this site, http://www.oemautosound.com/pc-353-194-ipo...ging-cable.aspx.
If any one is interested I have one available that I do not need. It is the stereo version (2 plugs) and doen not have the video output.
Cheers
Andy
PS. Frank, great thread.
Yeah, i bought a composite cable for my ipod (includes video RCA) that also charges the ipod aswell.
Is there a way to bi-pass the TV AV and go straight into the AUX in the screen i think it would improve the sound quality alittle.
Pat.
Hello,
I cannot find the TV tuner on my 2003 350 GT (Japanese import). I can see the Bose amp, but there is nothing on top of that.
I have the TV option, since a snowy screen appears on the display when TV mode is selected.
Do you guys have an idea where I can find the tuner ? I did look all over the boot with no luck.
Thanks all
Gerald
Pat.
with fiddling - yes.
zedexsix,
sedan or coupe.
Hey Chris,
Here is the picture you asked me for: post-52623-1214314612_thumb.jpg
You can see that there's nothing on top of the Bose amp.
I've also included a photo of the front panel
you can see that there is no tv button but an A/V one.
I think that an optional Xanavi navigation system has been retrofitted to the car. The third image is a remote control, see this link for more info. http://www.nissan.co.jp/EN/navi.html
The language is all Japanese.
What do you get if you disconnect your tv tuner ? I might have one hidden somewhere because of the snowy screen displayed when TV mode is selected.
Thanks again for your help.
Gerald
now thats different. never seen that. screen will complain with no tv tuner attached. keep digging its there somewhere. rip the carpet out of the side. I can't see nissan building a 10th harness for these things. tv antennas are back in that corner so the rest should be too.
pm me your phone number- want to chat :(
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
