Hi ... I may have missed it but can anyone tell me where the TV Tuner is located in the M35 Stagea.
Hi Grant
The TV tuner is located on the left hand side of boot behind the trim. Just in front of the pocket on the left in the boot. You will need to remove the trim panels to get at it.
Cheers
Andy
Hi Grant
Cheers
Andy
Thanks
Grant
  • 1 month later...
Hi Frank,
Any chance of re-uploaing the images for us as it looks like some have gone walkies and i want to see a few bits that are missing?
Cheers
Laine
Hi mate:
I don't know, form does not allow me to edit to re upload the picture.
You can also go one step further when intergrating the ipod through the stereo. All you can buy in Australia is the 3.5mm headphone jack to RCA plugs. The problem with using these with the stereo is that the volume is controlled from the ipod.
One better is a cable that plugs in off the standard Ipod plug in the base that goes to RCA and will charge the ipod. I purchased mine from the US from this site, http://www.oemautosound.com/pc-353-194-ipo...ging-cable.aspx.
If any one is interested I have one available that I do not need. It is the stereo version (2 plugs) and doen not have the video output.
Cheers
Andy
PS. Frank, great thread.
Yeah, i bought a composite cable for my ipod (includes video RCA) that also charges the ipod aswell.
Is there a way to bi-pass the TV AV and go straight into the AUX in the screen i think it would improve the sound quality alittle.
Pat.
Hello,
I cannot find the TV tuner on my 2003 350 GT (Japanese import). I can see the Bose amp, but there is nothing on top of that.
I have the TV option, since a snowy screen appears on the display when TV mode is selected.
Do you guys have an idea where I can find the tuner ? I did look all over the boot with no luck.
Thanks all
Gerald
Pat.
with fiddling - yes.
zedexsix,
sedan or coupe.
Hey Chris,
Here is the picture you asked me for: post-52623-1214314612_thumb.jpg
You can see that there's nothing on top of the Bose amp.
I've also included a photo of the front panel
you can see that there is no tv button but an A/V one.
I think that an optional Xanavi navigation system has been retrofitted to the car. The third image is a remote control, see this link for more info. http://www.nissan.co.jp/EN/navi.html
The language is all Japanese.
What do you get if you disconnect your tv tuner ? I might have one hidden somewhere because of the snowy screen displayed when TV mode is selected.
Thanks again for your help.
Gerald
now thats different. never seen that. screen will complain with no tv tuner attached. keep digging its there somewhere. rip the carpet out of the side. I can't see nissan building a 10th harness for these things. tv antennas are back in that corner so the rest should be too.
pm me your phone number- want to chat :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
