Hi ... I may have missed it but can anyone tell me where the TV Tuner is located in the M35 Stagea.
Hi Grant
The TV tuner is located on the left hand side of boot behind the trim. Just in front of the pocket on the left in the boot. You will need to remove the trim panels to get at it.
Cheers
Andy
Hi Grant
Cheers
Andy
Thanks
Grant
  • 1 month later...
Hi Frank,
Any chance of re-uploaing the images for us as it looks like some have gone walkies and i want to see a few bits that are missing?
Cheers
Laine
Hi mate:
I don't know, form does not allow me to edit to re upload the picture.
You can also go one step further when intergrating the ipod through the stereo. All you can buy in Australia is the 3.5mm headphone jack to RCA plugs. The problem with using these with the stereo is that the volume is controlled from the ipod.
One better is a cable that plugs in off the standard Ipod plug in the base that goes to RCA and will charge the ipod. I purchased mine from the US from this site, http://www.oemautosound.com/pc-353-194-ipo...ging-cable.aspx.
If any one is interested I have one available that I do not need. It is the stereo version (2 plugs) and doen not have the video output.
Cheers
Andy
PS. Frank, great thread.
Yeah, i bought a composite cable for my ipod (includes video RCA) that also charges the ipod aswell.
Is there a way to bi-pass the TV AV and go straight into the AUX in the screen i think it would improve the sound quality alittle.
Pat.
Hello,
I cannot find the TV tuner on my 2003 350 GT (Japanese import). I can see the Bose amp, but there is nothing on top of that.
I have the TV option, since a snowy screen appears on the display when TV mode is selected.
Do you guys have an idea where I can find the tuner ? I did look all over the boot with no luck.
Thanks all
Gerald
Pat.
with fiddling - yes.
zedexsix,
sedan or coupe.
Hey Chris,
Here is the picture you asked me for: post-52623-1214314612_thumb.jpg
You can see that there's nothing on top of the Bose amp.
I've also included a photo of the front panel
you can see that there is no tv button but an A/V one.
I think that an optional Xanavi navigation system has been retrofitted to the car. The third image is a remote control, see this link for more info. http://www.nissan.co.jp/EN/navi.html
The language is all Japanese.
What do you get if you disconnect your tv tuner ? I might have one hidden somewhere because of the snowy screen displayed when TV mode is selected.
Thanks again for your help.
Gerald
now thats different. never seen that. screen will complain with no tv tuner attached. keep digging its there somewhere. rip the carpet out of the side. I can't see nissan building a 10th harness for these things. tv antennas are back in that corner so the rest should be too.
pm me your phone number- want to chat :(
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
