My problem is that when I put my foot down on left hand corners i just get wheel spin, the car dosn't go sidways, i can just hear wheel spin, and the car dosn't power out of the corner very well at all, i've follewed similar powered GT-R's round the track, and I get slaughtered out of left handers, and the car tends to understeer as i can get the back to come round under power.
But out of right handers I get awsome power down, and the car will go sideways if I want.
I suspect my diff might need some attention, but i'm also wondering how much some proper suspention will fix it.
The shocks on my car are some Tenebe stuff (came with it), and some slightly firmer springs (sk calc'd F: ~3.2kg, R: ~2.5), I'm looking at the SK kit with the coil over conversion +bigger spings (from djr's thread), just don't have the $$ at the mom :) . tyres are Dunlop D02's.
I just want to know how to fix it, weather it's the diff, suspetion, or somthing else.
Here's some pics of me vs R33 with identicle power and screw type HA Bilsteins (i think they are firmer than the SK ones) coming out the hairpin at Symmonds Plains.
and me on the sweeper leading to the start/finish at Symmonds.
thanks
https://www.sau.com.au/forums/topic/184647-power-down-problems/
Defintely diff and not suspension.
Whose that guy that does good work with these diffs? I think Stuart Wilkinson motorsport or something like that. Someone please correct me. I know that's the place to go to get it fixed up properly.
Sounds like the diff could need attention?!?!?!?! Perhaps a fluid change can buy you some time. I know my std diff came good for a few thousand kms with soem fresh castrol oil in it.
But, when the dollars permit i woudl be doing the suspension before the diff. Just like my recent problems with braking stability. In goes new suspension and brakign stability problem all fixed. With more competent track suspension you may find that the diff problem is helped to the point that its nto as noticable. Better suspension will help you every corner. Better diff will help you on the slower stuff. LOL though both probably need attention :D
Who knows it could be right hand side shock is blown and the cars attitude is different from left to right unloading the car more one side to the other ??? LOL i dont know. I have just had recent experience with trying to use street suspension on the track with semis and actually going reasonably quick....suspension can be the root of all evil :)
Thanks for that, thought it was the diff. The suspention forum seems to get more responses than the drivetrain one :)
haha just noticed that there is a nice single from the left rear on the top pic.
looks like more money to spend :D
Thanks for that, thought it was the diff. The suspention forum seems to get more responses than the drivetrain one :P
looks like more money to spend :(
Yeh and the rear wheel looks more blurred in the pics than the front. Wheelspin .
the other thing I would look at is transfer case. I have a similar problem in my 32 GTR. car is a nugget at corner exit. revs flare up, sounds like wheel spin, but the attitude of the car changes very little (if at all) which lead me to thing clutch slip, but I cannot replicate it in a straight line, and loadded up, launching, shifting hard whatever the clutch does not slip. which has brought me to conclude slipping transfer case. an easy way to find out is if it's trasfer or diff is do a few laps in RWD and see if you still get the same feeling. if you do, then obviously it's diff, if not then I would be looking at transfer. good suspension wont hurt it either though.
Well an unloaded, ie inside wheel that spins will have much less an of an affect on the balance of the car than you may otherwise get. Remember that the GT-R drivetrain as standard only has a rear LSD, the front is open. Even then it isn't the tightest thing in the world & it you listen to most GT-R's on tight circuits you will hear the wheelspin. Mostly it doesn't upset the balance of the car.
hey roy
nothing wrong with street suspension , been using that for two years in r32!! >_< hehe
sound like diff, mate
cheers russ
LOL...By street I mean soft springs well under 200lbs that are at home with crappy low grip tyres and bumpy roads but not all that great when driven in anger on a track with grippy tyres. Tein Super Street with double the spring rate is whilst still street suspension…not what I was meaning. :)
Even if the diff was playing up…I would think that new suspension will make the car quicker even with a worn diff then the same supple, possibly worn suspension with a nice new diff
yeah that is why it's been hard for me to pin down, it sounds like wheel spin and feels like wheel spin (lack for rapid forward motion) but the attitude of the car doesn't change much which makes me think i'm losing power somewhere in the driveline (elimated clutch and rear diff) so that only leave the front (open) diff and the transfer case. I'm about to change all this though. nismo diff going in the rear and will get transfer case seen to and hope that fixes it.
last track day i stopped trying to feather the throttle and just planted it. and i found that when i do that i get revs rising going no where, then i see the tourqe gauge move, revs drop, and off you go. But by the time the R32 ecu pick's up wheel-spin, and decides to transfur the tourqe i've lost a fair wack of time (well it seems like it when a similar car is screaming away from you). So i'm thinking the trasfure case might be alright, had crossed my mind though. Just seems odd that out of right handers the car is awsome.
I assume the diff oil was changed at import time (10,000k ago), but i'm gunna see if i can get some oil and change it before the track day this sunday.
BB: the 2wd idea had crossed my mind aswell, might try it this weekend.
Troy - sometimes you have to think inside the box despite the damage it does to your psyche.
LOL...that nail in my head hurts :laughing-smiley-014:
Looking at the black lines... >_< yep ok.
sav man, did you get your Porka brakes all sorted? Be interested to hear how the car is under brakes with regards to pitching. Such a heavy car with such soft springs. When you say D02 Dunlops you means the DZ semi slicks ?
yep the dz semi's.
The semi's made a huge diference to the braking, still pitches, but as it's got grip now so it dosn't squrm round everywhere under braking. And according to the flag marshal at the Symmonds hairpin i was the latest on the brakes all day, so the pitching can't be hurting it too much. The porka brakes are awsome, no fade after a session (5L, sessions are about 45 mins and less apart) and the rotors are bright blue when i get back to the pits.
I still need a bigger master cylinder, currently tossing up between a 1" R33 one, and a 1&1/16" Partrol one.
I'd get the alignment checked anyway - eg too much negative camber at the back will affect power down. But yeah diff - some oils will tighten it up more than others if you want an interim solution. Does anyone know the theory here? I was told that redline light shockproof will make it a bit more shuddery when turning hard at low speed - so i guess that means the LSD plates grip more. Sort of make sense, because its also recommended for worn synchos. Or i could be talking out of my a** again.
There was also a thread on shimming diffs to tighten them up. Hello Mr Searchy.
Looking at the black lines... :blink: yep ok.
This is why everyone loves you Troy.
What's the theory behind a bigger master cylinder? Firmer pedal? Less travel?
Headaches as the theory probably doesnt match reality :P Will know in the next few weeks when i make a dramatic change in caliper size then maybe try to balance it out with MC size?!?!?!?!
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
