i guess everybody else new about the cd player issues..........mine is f#@ked and i never got the chance to use it. didnt think to check it when i bought the car.
what are the options?
repair or Ipod. ipod is cheaper.
Just replace the stereo/head unit = easiest option.
My cd player worked at first but eventually it ate my cd and wouldn't play it and wouldn't spit it out either.
I got an aftermarket head unit installed, and then I had to take the stock unit apart to retrieve my cd.
Any audio installer can do the install - its an easy job (according to autobarn who fitted mine - didn't have any trouble).
I did give them a printed copy of the instructions for a V35 ipod/stereo install (very similar to M35 dash) but not sure if they used it.
$80 & 45 mins for the install. very happy :)
You'll get better radio reception and better sound in general from an aftermarket head unit.
And they all have aux input nowadays, but some also have ipod compatibility so either way you can have the cd player AND the ipod, now thats having cake and eating it too.
Not an option for us AR-X and also the RX owners... In-dash 6 disc changer.... Needs some serious aftermarket panels to get that audio out and replace with a DIN/ISO standard unit that fits the RS....
Just get an iPod and a PA11-NIS.
Easy to install and works beautifully :)
ah thats right...sorry my bad.
one of the reasons I bought my rsfour 250t was that I could put my own stereo in
Hi all,
Just bought an M35 (250t RS Four V) from my girlfriend's brother (I'm Aussie, he's Japanese, I'm in Japan for the next 2 weeks).
Been enquiring about importing it into Aus through RAWS. Under RAWS guidelines it is legal for a registered dealer to import certain M35s with a production date from October 2001. Girlfriend's brother says this one was built in October 2000... and i'm looking at paperwork that says the same thing. RAWS importer I was talking to never heard of an M35 built before 2001. I've googled production dates, and 5 different sites say production of the M35 was from 2001 to 2007.
Are the paperwork and brother mistaken and it's actually a 2001?
Anyone ever heard of a M35 built in 2000?
Will be great if it turns out to be a 2001 because I can't import (or get compliance) if it is 2000.
Thanks for any help.
Langers
Hi all,
Langers
Something not right there. M35's were definitely not built before mid 2001. Other evidence of this is that a lot of the new bits in the M35 didn't show up in most Nissans until 2002 or late 2001 (VQ Engine, 5speed auto, Front Midship Platform, different styling, new dash layout etc). Also the series 2 stagea was still being built up intil sometime mid 2001 so it seems very unlikely they would have had 2 different models in production at the same time.
Does anyone have a part # for the plastic guard that protects the front axle and the hardware affixed to it?
Its the one after the big one that protects the bottom of the motor etc.
I had a major bottom out in Windsor not long after I got the car and the plastic protector is in pretty bad shape, thinking about getting it replaced when it get's serviced.
Hi all,
Langers
NM35 and HM35's began rolling off the production line in mid 2001.
If you give us the VIN, we can look it up in FAST for you to find the build date.
Yeah, mine went on the way back home after picking it up from the storage warehouse.
That was 2 years ago and I haven't yet replaced it.
Having said that, the part number you are after is 75881-AQ060
Edited by iamhe77
I recently replaced my 6 stack in dash cd player from my 25ot rs four with a dvd/sat nav eclipse unit from frankies auto electrics. Speak to Chris Rogers about the double din fascia and new a/c control buttons. Fits and looks sweet.
Hi all,
Langers
Another possible way to check build dates, that i have used on import motorbikes, hopefully same for cars is to check brake and fuel lines etc. By Law in japan they have to put month/year on brake and fuel lines as they have to be replaced every three of five years or whatever, thats why we get them cheap because of the prohibitive cost of doing all that work. Worth a look. Was quite commen on bike to find year xx bike had actually been built 6-9 months earlier etc....
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
