Have been looking at M35 info. Is there a twin turbo model available and is it able to be complied?
Nope. The only turbo model was from 2001-2004 and is the VQ25det.
Feel free to get one and add another turbo if you wish though :rolleyes:
There is one advertised in carsales in Qld. A dealer, says "Twin Turbo". Check it out.
Sorry Hugh.
Just a standard RS with the factory Aero kit and a Dolphin grill.
Considering all the piping is stock, there is no way he could be running an additional turbo in there.
Edited by iamhe77
maybe you should make an offer and then ask where the 2nd turbo is? Make them install it.... it would really go then
Please excuse me if this has been posted elsewhere but I couldn't see it.
I was talking with Northshore Prestige yesterday and they said they've now got approval for compliance of the VQ35DE engine (and that they were the first and only at the moment). Evidently there's a 2006 Stagea that should be available in a couple of weeks (it's been to the Ford factory in Geelong for testing) and quite a few more on the way.
He seemed to think it'd be priced at about $28-$29K.
No it has not been posted and you are correct.
Keep an eye on their web page next week.
yes it is, it doesnt appear to be installed on any other nissan engine that we can tell...........
$28-29k?? thats not unreasonable! thats very tempting to upgrade if i could get enough of a trade in for my car. which i probably wouldnt :action-smiley-069:
$28-29k?? thats not unreasonable! thats very tempting to upgrade if i could get enough of a trade in for my car. which i probably wouldnt :)
The import duty drops from 10% to 5% in 2010 that might equate to about a $1-$2K saving on a $30K+ car. So it'd be worth holding back until that saving takes effect. Though this may mean your car is worth less as well...
Its all swings and roundabouts and the value of the yen/$A/$US
and the fact that japan know what cars go where and adjust the price according ling. japanese economy also has a bit of bearing on it.
I've read quite a few posts about the limited life of the stock turbo. I was just wondering if this is specific to the M35 or not?
The turbo itself is specific to the M35, the turbo problems are not. I believe the issues are exactly the same as with earlier model stageas, however the M35 runs more boost as standard, particularly the ARX (going by the posts above or on prev page), making a turbo failure far more likely on the M35 than previous stageas.
The turbo uses a ceramic turbine which tends to come unstuck from the shaft or shatter when it is exposed to a certain amount of heat for a certain amount of time. If you search all over these forums (skyline R33 & R34 have same issue) you'll find that its generally agreed that 14psi is pretty much the limit for these turbos. more pressure means more heat and if you run 14 or higher psi for any length of time, sooner or later the turbo will break. Why Nissan released the car from the factory running such high boost on these turbos will probably remain a mystery. It seems they were aware of it because the turbo is apparently supposed to be replaced at 100,000km.
My RS is stock and runs around 11-12psi which by rights should be fine (my turbo is still going very well at 108,000km) but the bottom line is that if you buy an M35, bear in mind that the turbo may need replacing at some point. It should cost under $2K to replace it with something similar to the factory one, and from there it will likely never need replacing again.
Thanks for the info.
So if I end up with a Series I or II then the turbo may still be an issue (as per any any other parts of the car) but it is less likely as the boost has been running lower over it's life time (provided the owner hasn't increased it).
I'm sorry to say this but, I would think that a fair proportion of them out there have had the boost raised, even if the owner denies it! :D
I an really trying to like the M35, but that arse end is so ugly. If someone was to make adecent rear lights kit, like was done for Commonwhores, I may be tempted. Front and side, AOK, but...........
I have bBenny,s pic as my desktop.
Nissan made the arse end like that just to keep the cops off my back. Works a treat, even with a 3 inch straight through exhaust.
Just gotta get some Volvo badges for the back and I will be in the clear.
You could always paint the top part of the lights to match the car...
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
