its only limited to around 30% under about 3000rpm
And its a pain in the arse to tune around. I still have the throttle restriction, my 0-100 time would be around 4.5 seconds but it could be much better.
I think it could be related to speed, under 30kph perhaps?
im wondering how you intend on getting around speed cut :?
4.5 is damn quick. what mods have you got to get those numbers?
(i just had a look at your Garage). You gave exhaust 6/10 and intake 10/10? Did you do a full exhaust turbo back? or just cat-back?
No more boost/mods to pull those numbers?
Edited by Sage222
Plenty of both, I haven't updated the garage for a few months.
The previous exhaust was too loud so I bought a s/h cat back and fabricated my own 3.5 inch dump into a highflow cat.
I run a fairly small highflow at 20psi on E85. Current tune is 300awkw.
  • Like 1
Hang on... a custom exhaust, some ethenal, a high flow turbo running 20psi and you make 300awkw?? wow thats impressive.
Can the factory transmission, ECU, and injectors handle all that?
(you have me very interested) :D
He has an FMIC, upgraded trans, 610cc injectors, Tomei fuel pump and is running an E-manage Ultimate.....plus a couple of other home made bit's all of which you will need.
How much all up you reckon Scotty? 6-8k? Pretty good value I'd say...
Then again a friend of mine got his stock 04 WRX to 190 awkw for 6k...all done at STI at Docklands...
Gearbox wiped out the budget, 4k there, Highflow was another 2k, the rest was bit by bit. I would guess 10k total with me doing all the labour/fabrication.
200awkw is about the limit of the stock intake, stock turbo will flow that at higher boost but will then fail. I would be interested to see what a stock setup would do on e85...
Really? I thought M35 had ~140 - 150 awkw...so exhaust adds 50 awkw!???
Yes, You are correct..
I think Cam is referring to adding an Emanage or something similar to produce a more efficient result that should be tunable to 190kw on the stock injectors.
Scotty, What mods did you do to the gearbox to cost $4K??
Valve body upgrade, metal plates between the clutches laser cut from thinner material so they could fit extra friction plates, Dominator 3k high stall torque converter. It was the first one they had seen, its not like other RE5's apparently.
I think I hit 179awkw on stock boost, if the standard turbo was steel wheeled, 200 wouldn't be a problem.
  • Like 1
Yep, hence what I typed.
Bargain! :)
Should be able to get around that power level from stock with just an exhaust and tune on a VQ25det M35!
OK for the tv to work youll need a new tv tuner, whats available now im not sure that Asuka dont sell them (so i read)
getting the tv working while youre driving is not advisable and against the law, but if you HAVE to, there are override boxes that can do all this and literally just plug in. they come from japan, im surprised your car didnt have one fitted already!
check under the DVD tray andsee if there is a green light that is also a button. thats the override button for the tv.
  • Like 1
yeh im pretty sure i dont have one.
looking at the Trans ecu it looks like something was added and then taken off back to stock. Both me and scott assumed it would be the overide.
where can I get a Tuner from? its it a simple Jaycar type mod or is it more complex than im thinking. I was expecting it to be like the FM Band expander.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
