If the tune is correct and you have a bit of headroom in the injector, you shouldn't have an issue.
If your maxing out your duty cycle and your cheating by bumping up the base fuel pressure just make sure the flow pattern of the injector is still up to spec. Some injectors get very messy when you up the base pressure. I prefer standard base pressure and run the CORRECT sized injector for the application.
I'm with you on that paul
Sounds good then.
I'm getting close to maxing out the AFM, but injectors should be fine.
For me, this is a decision between throwing in the ID1000s now, or when I eventually do an E35 tune. If I need them now, I'll put them in. But sounds like I don't?
Car is running stock turbo and only half an intake pipe. Not the most serious mods.
I would agree with you on the injectors Leon as even at 18PSI with my car my Wideband never gets over 10.8 unless under load going up a hill then is gets to 11.1. However the AFM is well and truly maxed giving readings of 5+...and I know my duty cycle is over 95% at times....I have also seen 100% quite a bit......I can live with that on the street as I am hardly ever up it.
However I would never track it without bigger injectors and the AFM clamped.
P.S. I think its awesome how the car has worked out its tune with the extra pressure at 14v with the Walbro on mine....it would be very interesting to try a set of 440cc injectors in the car with the standard fuel pump to see if/how it runs.
Craig, I am impressed that your car runs so well on stock injectors, with just the fuel pump pushing more through (thought you might've surpassed that). I'm still tuning mine (adding fuel mainly) but my max injector duty cycle is 90% as of today. After the intake went in, but before the FPR, it was close to 100% on occasions.
I think 440cc injectors & standard pump would be a similar result to the opposite (Walbro & std inj). Do you think the ECU would learn it over time?
And Paul, I too agree. In a perfect world with lots of spare time and/or cash you would correctly size the injectors & leave fuel pressure alone. But the point I was making was that it wasn't necessary to stress over injector sizing with the mods that I or Ryan have done thus far. Especially since upgrading the fuel pump gives higher pressure as a by-product. Can't see anyone would change the FPR to a lower pressure just to counter the new pump, lol.
  • 3 weeks later...
There is a few Hypergear turbos getting around, I doubt any have been tuned so don't take the power output too seriously, yet.
Near factory response is hard to believe too, it looks about the size of a Sierra stage 1 so it will probably come on around 3k. Not a bad price though Stao. :thumbsup:
There has been bit development in that high flow as I had a customer whom own a work shop near by was happy to trail all of the combinations and the best felt on road is some thing in between a 3071 and 2871 with custom trimmed up turbine wheel with FNT turbine modification. It is touch smaller then the usual profile that I normally run in the skyline turbos which some of you noticed the HP rating isn't as high.
I've also modified the bearing housing so they can work with stock oil supply, braided oil line is no longer required.
Test car was a auto M35 with cooler and exhaust only and that high flowed turbo was excellent to drive with on road. I believe the best option is running the SS1PU on the VQ25. I'm consider making a custom mould for when more M35s comes into the country.
The stock housings flow ok, all you need is a spare set so the wait time is reduced. I haven't seen any of these turbine housings cracking yet either Stao which is good.
Someone fit one and get it tuned... :D
  • 5 weeks later...
Can anyone who has installed a power steering cooler tell me where the best place is to connect the cooler?
Anything fancy that's required or just replace fluid at the same time?
Hasn't been replaced yet, figure I can use the Valvoline auto trans fluid I've got left.
Loop it through one of the lines going into the bottom of the radiator
no dont do that, thats for the transmission cooler circuit.
put it before the pump, you can use the hoses running up the the filler bottle. keep the stock ones, and just replace the hose with good quality type
Cheers Iain. Do you know offhand what size the hose is?
Thanks!
Does any one know if the VQ35DE airbox is the same as the VQ25DET airbox? Or is they can be swapped?
Same airbox(PM35,V35,NM35,G35).......but the VQ35 comes with a power duct I think
Edited by Jetwreck
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
