There are no grooves, they just push back in. Make sure you keep an eye on the fluid reservoir as Alex said.
Thanks peeps, will get on to this on the weekend.
Once I take the fluid out do I leave the resivour cap off until I have pushed the piston back in or just take out what I need to, replace the cap, then go work on the calipers, push them in, start the car and then refil if required? Or am I missing a few steps? Is it ok to give one of you guys a call RE this just to run through it?
always replace cap whenever your not filling or taking out- prevents debris and brake fluid is hydroscopic, meaning it attracts water.
may have just made that word up. :P
Don't take all of it out (then you'll have to bleed them all), just a little bit,like inbetween the max and min, and then push the piston back a bit and check it again- you'll get the idea.
Ooooh; sooo close!
Hygroscopic; Readily absorbing moisture, as from atmosphere.
The rest is fine. Don't forget to work from the furthest point to the closest point; think rear left corner to front right corner.
Now; back to your normal programming. Grammar Nazi out.
Edited by Daleo
Ooooh; sooo close!
Lol, had heard it said, but not written before. Thank you. :3some:
  • 1 month later...
WHEY! +1 Another M35 owner to the list here as of today.
4th consecutive Nissan owned. Such a nice car, absolutely love it. Smooth, comfort, with a big slap of boost on tap.
Must admit, she's thirsty though!
Like all 1.7tonne turbo v6's
Mine's ~1.8t plus whoever & whatever I have inside. I could get into the 9's (just) on a trip, otherwise 10.5 - 11.0L/100km on stock turbo. Don't know current consumption since changing turbo, but probably a bit worse.
  • 4 weeks later...
Hey GUYS, I'm interested in the M35, they're all auto !! i would like to convert one to manual !
For example: a 2002 model Nissan Stagea (NM35) 250 GT RS 4 V, has a VQ25DET engine, however, the 2002-05' Nissan Skyline (V35) comes in a VQ35DE but in a manual.
Is it possible to connect V35 3.5litre gearbox to the M35's engine ?
Seb
(ps- sorry if this has been said somewhere else as I haven't seen it yet)
Hey guys, I got an airbag light flashing on the dash - no idea how or what has triggered it. Just keeps flashing continuously. Anyone had this before?
Yeah, so many people it's not funny.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
