coils are coils, but you would need to stuff around mounting them, they would not have bolt in direct fire ones like jjr/splitfire/owm
coils are denfinately not all the same. the aftermarket stuff has really come a long way. the nissan std coils r quite good, but imo there is a whole range on very powerful coils out there that would b better than std (and prob cost around the same sort of $$). example, i changed to MSD coils from stock ones in my V6 commodore and dropped from 14.5 to 14.02 with just the coils and a small adjustment to the tune in the last 1000rpm (merely to correct a/f ratio). making brackets isnt that envoled either.
Edited by Raysboostin
  • 3 weeks later...
Well i have some issues with Splitfires, the first set died 6 montch after purchase 4 coils startred to die, and it looks like that migh be the case again, either way my Central 20 ECU and splitfires don't like a gap above .8 mm at 15 psi
The issue is clearly with the ecu/tuner combination.
Have your tuner pull his finger out of his bottom and check the coils dwell vs rpm has been setup correctly.
If its not it will either provide a weak spark or overheat and kill the coils quickly.
My bets are on the later.
does that mean if i put aftermarket coilpacks in i will have to get a re tune. you cant just put these in?
my splitfires died after only 8 months :ermm: . i just hope the workshop that installed them will replace them under warranty, guess i'll find out tomorrow when i speak to them
Edited by into oblivion
are you sure your central 20 ecu supports sequential ingition and is not operating in batch mode or something ?
out of the 50-60 or so splitfires we have supplied in the last 12 months or so we have NEVER had a single one fail
out of interest OEM coils are 180 each trade price and the coil pack loom (engine sub harness) is about 200$
standard ecu
mods - zorst, FMIC, pod
only mod i added since splitfires was manual boost controller set to 10psi, 200rwkw
and i don't thrash my car, only done 5000km since coils changed to the splitfires
standard ecu
ok as you didn't fit the splitfires your self I'm assuming your guessing that the coil packs have died.
In other words you haven't pulled the coil packs out yourself, inspected them did the usual trouble shooting one does before they come to the conclusion that something has died. :ermm:
What brought you to that conclusion?
If its started popping it can be maaaaaaaaaany things. :D
The AFR's are too rich.
Plugs need regapping.
Plugs need replacing.
Ignition has crapped its self (if its a s1).
So fingers crossed its something silly. :D
yes i am guessing so probably shouldn't assume :D
but the car makes excatly the same noise as when my OEM coils had died.
last week it started stuttering/shaking at idle. now at 4000rpm onwards it pops to the bs
took it to my other local mechanic and he had a quick check of the plugs/sensors/af meter couldn't find anything obviously wrong
plugs were replaced same time as splitfires installed
don't have an a/f ratio gauge
series 1
yes, hope hope it's something basic. otherwise hope hope it's still covered under warranty. i've still got the receipt from the mechanic.
anyone know what the warranty is on splitfires, someone please say 12 months?
  • 3 weeks later...
found these coil packs on ebay. they are called super spark coils and they say that they give you 10% more spark and they are to suit RB20, RB25 and RB26. at $499 what do you reckon? has anyone else heard or know of anyone using these.
they look to me to be similar looking to the JJR packs
http://cgi.ebay.com.au/SUPER-SPARK-Coil-Pa...1QQcmdZViewItem
They are exactly the same as JJR, only $100 dearer per set.
Kudos sell SUPER SPARK doesn't he???
Im about to buy new coils myself but haven't decided if i will go JJR's or Splitfires :bunny:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
