yeh, thought we would give it is much as we can as my tuner and i want to give the E85 a go. the added octane and cooler temps should allow it.
Sounds like excellent news!
11:1 is a good compression ratio, a little higher than original...
Cant wait to see/hear a video of the engine roaring...
  • Replies 812
How much parts do you need to change to use E85?
I heard that from stock, you only need to change the injector, fuelpump and fuel filter and it should be able with a tune to run E85, or am I mistaking?
yeh, its all Gary stuff. the brakes are 330mm, wanted to run 17s, speaking of which, i picked a nice set of 8s & 9s up today.
suspension and brakes look good Stu. Is that blisteins, eibach springs and noltec adjustable bushes?
and the brakes are the 356 like we run?
no, that all sounds about right. i am running two 040 intank pumps & 42pound injectors.
Looking at your rear shocks you are running a GTR rear cradle. Would you happen to know the weight benefit? I mean do the bigger shafts just offset the alloy hubs?
The upgrade to the GTR cradle wasn't done for a weight advantage but for a strength upgrade. I don't think anything was weighed when the conversion was done.
pics,,, Rays Daytonas 17x8s & 17x9s
nice. they were a good buy. I was nearly going to grab them as a spare set for the silvia. then remembered I already have 3 sets of rims for the silvia.... :P
A complete GTR cradle compared to a GTS or GTS-T would be similar in weight but provide a lot more strengh to handle the extra two cylinders.
We did the conversion to alloy GTR hubs on Clinton's R32 and saved 3 kg per hub (the important part though is the reduced unsprung weight).
Heavier parts include the shafts, diff housing and additional front diff support bracket.
Common parts are the top arms, traction arms and lower arms (the only difference on lower arms is the balljoints).
hey Roy, i agree with Victory, the weight difference in the shafts will be compinsated for in the alloy hub assy. you may end up giving a kilo or two away in the centre but thats it. i couldnt tell you if the cradle assy was any heavier though. its difficult to weigh these big items, especially on bathroom scales.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
