Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :P
I think you'll find they are shiny new TIIDA's.. not pulsars.. lol..
excellent car.
Will buy issue 10 if it's in there.
  • Replies 812
I think you will find that the dealer principal rang Nissan Aust to make sure it was okay and a certain dept started asking questions.
Oh an import hey,,,,NO
Oh in an Import magazine,,,NO
Oh it's got what under the bonnet,,,definately NO WAY.
Whilst the dealer network are lets say "mostly happy" supplying parts for private imports,,,the manufacturers are not.
Neil.
All I can say is,
It was the best sounding car on the day!
It was also the cleanest car in the morning!!!
Stu - when I was flagging at the flip flop, your car gave me blood.... :(
thanks Chris, yeh roy, by lap 3 of the first session i was already bored of the track and decided to check the infield out between turns 1 & 2. that one was painless. the next time i did the same thing but this time i went in side-ways and damaged the front bar. I thought id make sure the job was done correctly by going off after turn 2 and before the bridge. but thats all lol. Car was very light in the arse on braking, mid corner, corner exit, excelleration etc, basically it tried to swap ends on me every where. i was even loose on the straight in 4th at one stage, but after getting some good advice on lines through turn 1 i was more confident into turn 2 which i was most shit scared of. mechanically it was great, had an oil leak in the tranny in first couple of sessions but sorted that out. just more track time and some adjustments to get it to behave and it wont be as much of a handfull. but it was cool knowing i could squeeze the gas and light the tyres up. just had to make sure it was pointing straight. all in all i was very happy seeing i had never driven the car before and or driven OP.
All I can say is,
So Stuart have we converted you to going around corners now. Or are you still interested in straight lines?.
I think I said it way to many times,,,but your car sounds so fat coming down the straight.
I loved it mate.
Neil.
As others have already said this was probably my fav car of the day and seeing as though you were in my group all I got to see of it was either you overtaking me down the straight or you spinning off multiple times infront of me at turn 1-2. Actually from memory you gave me a wave when I gave you room coming out of the last corner onto the main straight and then I waved you back as you spun off at turn 2 and I went back past :(
Why people bother with RB's when you can throw a v8 in a skyline is beyond me.
most definately Neil, you know you have done an honest days driving when your hairs all wet and so is your undershirt.
5-15 minute sessions is more driving than a drag racer would see in a year.
Thought about it after we got home but i should have let you have a steer. I dont think anyone else would fit in the seat.
Next time.
I loved it mate.
Neil.
My dream has always been an LS1 in a skyline of somesort, just wish I had the knowledge, skill and money!
So whens the next outing in it Stu?
ill give it a rest now and concentrate on having this baby. Missus is 37 weeks so anytime now.
Have to sort out these handling issues to make it a bit safer lol.
everything is for sale Chris.
Great to hear it all went well, would have loved to hear the thing, guess ill have to wait till its out a wakie.
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year ;)
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year :dry:
I destroyed a bearing at OP GP on Friday...
I'm currently weighing up an LS2 in there instead of rebuilding the RB30 bottom end...
Stu: Got any sources for getting crate LS2s?
Lingenfelter LS3 TT
Do it, and I'll literally bow down at your feet :dry:
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
