Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :P
I think you'll find they are shiny new TIIDA's.. not pulsars.. lol..
excellent car.
Will buy issue 10 if it's in there.
  • Replies 812
I think you will find that the dealer principal rang Nissan Aust to make sure it was okay and a certain dept started asking questions.
Oh an import hey,,,,NO
Oh in an Import magazine,,,NO
Oh it's got what under the bonnet,,,definately NO WAY.
Whilst the dealer network are lets say "mostly happy" supplying parts for private imports,,,the manufacturers are not.
Neil.
All I can say is,
It was the best sounding car on the day!
It was also the cleanest car in the morning!!!
Stu - when I was flagging at the flip flop, your car gave me blood.... :(
thanks Chris, yeh roy, by lap 3 of the first session i was already bored of the track and decided to check the infield out between turns 1 & 2. that one was painless. the next time i did the same thing but this time i went in side-ways and damaged the front bar. I thought id make sure the job was done correctly by going off after turn 2 and before the bridge. but thats all lol. Car was very light in the arse on braking, mid corner, corner exit, excelleration etc, basically it tried to swap ends on me every where. i was even loose on the straight in 4th at one stage, but after getting some good advice on lines through turn 1 i was more confident into turn 2 which i was most shit scared of. mechanically it was great, had an oil leak in the tranny in first couple of sessions but sorted that out. just more track time and some adjustments to get it to behave and it wont be as much of a handfull. but it was cool knowing i could squeeze the gas and light the tyres up. just had to make sure it was pointing straight. all in all i was very happy seeing i had never driven the car before and or driven OP.
All I can say is,
So Stuart have we converted you to going around corners now. Or are you still interested in straight lines?.
I think I said it way to many times,,,but your car sounds so fat coming down the straight.
I loved it mate.
Neil.
As others have already said this was probably my fav car of the day and seeing as though you were in my group all I got to see of it was either you overtaking me down the straight or you spinning off multiple times infront of me at turn 1-2. Actually from memory you gave me a wave when I gave you room coming out of the last corner onto the main straight and then I waved you back as you spun off at turn 2 and I went back past :(
Why people bother with RB's when you can throw a v8 in a skyline is beyond me.
most definately Neil, you know you have done an honest days driving when your hairs all wet and so is your undershirt.
5-15 minute sessions is more driving than a drag racer would see in a year.
Thought about it after we got home but i should have let you have a steer. I dont think anyone else would fit in the seat.
Next time.
I loved it mate.
Neil.
My dream has always been an LS1 in a skyline of somesort, just wish I had the knowledge, skill and money!
So whens the next outing in it Stu?
ill give it a rest now and concentrate on having this baby. Missus is 37 weeks so anytime now.
Have to sort out these handling issues to make it a bit safer lol.
everything is for sale Chris.
Great to hear it all went well, would have loved to hear the thing, guess ill have to wait till its out a wakie.
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year ;)
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year :dry:
I destroyed a bearing at OP GP on Friday...
I'm currently weighing up an LS2 in there instead of rebuilding the RB30 bottom end...
Stu: Got any sources for getting crate LS2s?
Lingenfelter LS3 TT
Do it, and I'll literally bow down at your feet :dry:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
