Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :P
I think you'll find they are shiny new TIIDA's.. not pulsars.. lol..
excellent car.
Will buy issue 10 if it's in there.
  • Replies 812
I think you will find that the dealer principal rang Nissan Aust to make sure it was okay and a certain dept started asking questions.
Oh an import hey,,,,NO
Oh in an Import magazine,,,NO
Oh it's got what under the bonnet,,,definately NO WAY.
Whilst the dealer network are lets say "mostly happy" supplying parts for private imports,,,the manufacturers are not.
Neil.
All I can say is,
It was the best sounding car on the day!
It was also the cleanest car in the morning!!!
Stu - when I was flagging at the flip flop, your car gave me blood.... :(
thanks Chris, yeh roy, by lap 3 of the first session i was already bored of the track and decided to check the infield out between turns 1 & 2. that one was painless. the next time i did the same thing but this time i went in side-ways and damaged the front bar. I thought id make sure the job was done correctly by going off after turn 2 and before the bridge. but thats all lol. Car was very light in the arse on braking, mid corner, corner exit, excelleration etc, basically it tried to swap ends on me every where. i was even loose on the straight in 4th at one stage, but after getting some good advice on lines through turn 1 i was more confident into turn 2 which i was most shit scared of. mechanically it was great, had an oil leak in the tranny in first couple of sessions but sorted that out. just more track time and some adjustments to get it to behave and it wont be as much of a handfull. but it was cool knowing i could squeeze the gas and light the tyres up. just had to make sure it was pointing straight. all in all i was very happy seeing i had never driven the car before and or driven OP.
All I can say is,
So Stuart have we converted you to going around corners now. Or are you still interested in straight lines?.
I think I said it way to many times,,,but your car sounds so fat coming down the straight.
I loved it mate.
Neil.
As others have already said this was probably my fav car of the day and seeing as though you were in my group all I got to see of it was either you overtaking me down the straight or you spinning off multiple times infront of me at turn 1-2. Actually from memory you gave me a wave when I gave you room coming out of the last corner onto the main straight and then I waved you back as you spun off at turn 2 and I went back past :(
Why people bother with RB's when you can throw a v8 in a skyline is beyond me.
most definately Neil, you know you have done an honest days driving when your hairs all wet and so is your undershirt.
5-15 minute sessions is more driving than a drag racer would see in a year.
Thought about it after we got home but i should have let you have a steer. I dont think anyone else would fit in the seat.
Next time.
I loved it mate.
Neil.
My dream has always been an LS1 in a skyline of somesort, just wish I had the knowledge, skill and money!
So whens the next outing in it Stu?
ill give it a rest now and concentrate on having this baby. Missus is 37 weeks so anytime now.
Have to sort out these handling issues to make it a bit safer lol.
everything is for sale Chris.
Great to hear it all went well, would have loved to hear the thing, guess ill have to wait till its out a wakie.
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year ;)
I really have to stop reading this thread, its making me want to do bad things with an LS2 and my R33, might start it next year :dry:
I destroyed a bearing at OP GP on Friday...
I'm currently weighing up an LS2 in there instead of rebuilding the RB30 bottom end...
Stu: Got any sources for getting crate LS2s?
Lingenfelter LS3 TT
Do it, and I'll literally bow down at your feet :dry:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
