Spotted 2x maroon liners in kawana. think it was insomniac?
nope was most likely bunta and R33skyliner, they were up here for insomniac's wedding to use there cars as the wedding rides, and i went and met up with them after wards at kawana shops. lol
Edited by 85URK
Was down the coast today test driving a couple of cobra kit cars. (My gf's dad wants to build a cobra or buy one turn key)... Anyways. Saw about 50 or so skylines....
Also spotted gorden's (predator) house. Didnt look like he was home so i dodnt stop in to say hi. But i did beep just incase.
Man what a day.... I thought u got looks in a yellow skyline. Well lets just say a cobra is like forbiden candy.... Ummmm
WHAT THE HELL!! I drove past on millers rd Kuraby this morn about 8ish what i thought was a white R34 until i looked at the back and seen R33 tail lights?? Is it possible to do a R34 front slash R33 rear? he beeped and waved and i gave a wave back (horn no workin) The rear tail surrounds where black too. Looked damn awesome!!!!!!!!!!!!!!!!
If ur here SPEAK UP i have some questionz.
Very Unique looking car.
spotted a black 34 with gtr kit Ride Me .. gave wave to owner on broadwater road mansfield
I've seen that one before, can't remember where though. I go along Broadwater Rd twice most days tho to and from work, so quite possibly there :D
you can do anything if you have enough money
spotted a blue 32 on the smith st exit,
i stopped and reattached her cooler pipe for her, nice lookin 32 tho.
Thats a very very nice thing to do James. (being serious, most people wouldnt pull over at all, hot, nice car or anything, they just keep driving)
2 things tho, was she hot, and if so did you get her number :D
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
