  • 1 month later...
Spotted 872KLL a nice gtst 32 in surfers centro car park today... i giggled, then i took a picture,
if you are on here, it is good to see a fellow skyline driver who cares about their car.
dont think you could have hugged the pole anymore...
This is so cool to see, I own the car now after 8 years from this photo. She's still going strong. IMG_3211.JPG
probably has less kms showing on the dash since then as well
  • Like 1
  • 3 weeks later...
  • 8 months later...
  • 2 months later...
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 3 years later...
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
