I don't think we will loose her dulcet tones........ what are you doing that she talks to you? LOL.
The only time she talks to me is when i try to run out of fuel i the quest to fill up on Tuesday.
My '01 300GT Premium had her tell me a standard safe driving type of message when I hit the top left button under screen. I also got a noticably slower voice when I hit the nanny meter at 180km/h - always cracked me up - it was like she was talking me off a ledge LOL Where as the normal snappy voice when needing fuel!
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4009810
  • 4 weeks later...
Good news!
The conversion is complete and they are in the process of testing the software to ensure it is without errors.
We are still working towards a Septemer release so not far away.
Once I have screen shots I will post them up.
We anticipate that you will be able to install the software at home with some simple instructions but this will be confirmed over the next few weeks.
The estimated cost is $200 for the conversion.
I will let you all know when there is an exact time line.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4064584
Good news!
Cheers
Andy
Thats is awsome new simple and cheap cant get any better ! Good work Andy !
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4064959
Hey Andy it seems theres a bit of interest but people who actually go ahead with it may be a differnt story, is there going to be a limit on these disks ? can they be reused ? If there is going to be a limit maybe you should start getting members to put a small deposit down just a thought.
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4066535
Once we are ready to go there will not be any limits of the number of conversions we can do and the disc will not be reusable. This will not delay things though as the each conversion disc will be individually created as it will relate to a security code that is created during Disc 1 of a 2 disc install. This is necessary to protect the security of the software that has been created to do this conversion.
I am sure once people see who good this looks I am sure that many people will be happy go ahead.
I would rather wait wait till it is all 100% perfect before we ask for any money. I am taking note of the people who have expressed interest at an early stage and if they are happy to go ahead when they see the final product, I will ensure they are given the opportiunity to be one of the first with the conversion.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4066632
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
