Ok I was driving out tonight and the compass works BUT it was off by 90 degree...
For example if I am facing South, it will point West, if I am facing east, it wlil point South....
How do I fix this... anyone know if there is a 'sensor' box under the dash that I can perhaps turn sideways 90 degree to fix it?
Easily fixed...
drive Sideways, come on Rianto... think logically man.
It says something here about the tilt angle or dip, and as you progress further into the northern or southern hemisphere the magnetic field will point partially downwards....
So I guess if they set it up to take into account this dip in the northern hemisphere, it would be doing the opposite of what adjustment would be needed in the southern hemisphere.
I had mine up the last night and it was off exactly 180 degrees, that is heading North it pointed to South, heading East it pointed to West, heading West pointed to East. I would think if someone were changing the software it would be fairly easy to swap N and S, and W and E? or maybe turn or flip the unit it is in 180 degrees?
I'm in Perth...
Hi guys... any word/update on the jap to english conversion yet?
On a related note can i just clarify a few things as i'm looking at buying a 350gt in the next few weeks.
I understand that the gps isnt going to be converted, my main concerns are the computer on the premium.
From this thread am i right to assume that the conversion is only planned for the series 1 350gt.
Is there any language conversion done at all on later series??
obviously if late model 350's have no translation planned/possible then i should be looking at a nice condition series 1.
thanks for the help.
If you look a few pages back -Programmer is finalizing software for models up to 10/2004. But depending on demand may look at models thereafter.
I've read through the entire thread, and it looks like the programmer has been finalising the software for quite some time.
As stated, the reason for my interest is that I'm looking to buy a 350GT, and I'm trying to balance the compatibility of a language conversion with getting the newest model possible.
get the newest model possible no question about that. If the language conversion comes through treat it as a bonus no biggie. I've lived with the Jap writings for close to a year now...keeps its import authenticity :D
+1
Got my navi orginal dvds back today -Compass is spot on ! Sounds silly, but I hope people understand "True North"--this why some might think its about 90' out. Also I notice there are several settings (dont underastand them all yet) where you can fix a position and compass adjusts to N,s,e,w of that postion.
But if you check the GPS menu it always is reflects car postion to true north. Boy I dig that groovy japanese voice on the navi also.
The below explains true north from magnetic north. Basically True north is geographical north which is north pole. Whereas magnetic north is effected by the earths magnetic field and axis - is near canada.
http://academic.brooklyn.cuny.edu/geology/...a/magnetic.html
Sorry to complicate things when I posted prev. I meant to add that people often refer to North as the northern part of the city/state rather than either of the above.
I was surprised by the talking too! It was on the first (top button) (mine 11/05 model). Also noticed when you press ETC options it talks when navi disc is in. (instead of chimes when not). Will have to tie my borthers japanese partner in the seat and get her to translate one day !.
Japanese Partner of your brother and she hasn't translated yet?
What's wrong with ya?
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
