Nah, unfortunately those two screws are just to remove the memory slot component. This can be seen in the picture with the lid off and the PCB showing with a few components sitting on top of it. Basically, the hard drive is on the other side of the green PCB that you can see in the photo, approximately at the level (but slightly lower) than the brown strip in the front shot of the unit. Basically to get at the HDD, you need to remove the CD ROM and to remove the CD-ROM, to me it looks like you just about to remove everything. Gonna take a long time and patience, not to mention a helluva lot of nerve!
May the force be with you :)
ok its a different unit I was thinking of. there is one that nissan make that you can access it from the front.
allow a day to strip / pull and reassemble it.
once you get the image done/cracked and redone prepare for a barrage of 'can I get a copy' emails :)
does anyone know if the maps stored destinations are stored on the DVD drive or somewhere else?
when mine was converted to english, brad had a pre-converted dvd drive that we just swapped over.
ive just got the maps running for the first time and found the destination marked as "home" in Toyohashi and im wondering if that could be the actual Japanese home of my car
plus it is showing the position marker as being about 10km directly out from Fuji heading SW by boat
Edited by Deep Dish V35
I would of thought that the favorites menu which has stored places would of been stored on the dvd rom. I dont think it can write to a disk. It can only read a disk.
Someone tell me if i'm wrong.
Wow, that unit looks vastly different with many more terminals on the back than the USDM 2010 coupe. I was thinking of taking mine out to see if I can work out a telephone mute type of volume control for my system without affecting the volume of an actual phone call via the bluetooth. Yes, I know that sounds silly but the application I have in mind calls for the stereo to be muted without affecting phone calls so that I can hear an alert other than a phone call when the stereo is blasting.
Failing that, I'm thinking I can probably just fudge the device so that it triggers the Voice control but I can't remember if that mutes the stereo for the voice command or not. I'm working overseas at the moment but my brain is running 24/7 thinking about how I'm going to solve this challenge.
Nice work with pulling it out and taking the photos though. If you ever get a chance to get more detailed photos of the circuit boards themselves, they may prove to be handy in my research for this other project. Don't go out of your way for it though. Best of luck with the conversion. I'm quite happy to keep mine in Japanese. It gives my vehicle a little character. :)
Besides, with Nissan introducing the G37 locally, maybe we'd have the good fortune of the Bose-equipped vehicles actually getting the same hardware - unless Nissan expect this and will screw us over. Time will tell.
  • 2 months later...
I never get an answer Fedor just says he is busy with it. If Andy reads this he can ask Fedor about the economy screen.
I just have to get more dvds so I can copy it or you can bring your memory stick over and I can give it to you and you copy it onto disk yourself
hi, i just wondering how can i use Navigation/DVD/TV? actually i turn on tv then there has nothing on there,however i can hear sounds for speaker which should be come from TV Channel. i have press navigation button which doesnt work, there has nothing come out from screen. can u help me for those questions? cheers
You'll need an Aus tv tuner if you don't have one already. Japanese tv tuner won't pick up picture over here (assuming you are in Australia that is).
Navi won't work over here either.
This is pretty frustrating.
I have read 15 pages of this thread from the start and there is nothing relevant in the first 15, just chatter.... Software hasn't even been developed. Thread could really do with a clean up or a new thread with definitive answers!
So before anyone says 'read' - all I want to know is if software is available for 2004.5 (s2) or 2006 (s3)? Please :-p
  • Like 1
Have now read all 53 pages!!
Answer is there is currently no solution for s2 but being worked on.
It sounds as though it ill be easier to just splice in a tv tuner and external gps unit for display ad be done with it.
S2 should be released in November. It is very close to being ready.
http://www.xanavi.com.au/Xanavi/Xanavi_Language.html
Sounds good. But no s3?
Reason I ask is i am in the market and it is important for me to get it functioning in English with the ability to add gps and reverse cam.
If s3 is a basket case then it affects my decision.
Brad, do you know if Fedor retained the Km/L or did he change it to L/100km for the series 2?
I would say it would be the same as series 1. Ill ask him next time I speak to him. Not alot of people have asked for it that way. But I could be wrong
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
