  • Replies 60
My 2way is noisy as hell, mostly when it's cold - it either skips or the clutches chatter away. Once it's nice and warm it's barely noticeable.. might try some new oil..
Oh and it is a bit clunky but I was warned of that.. button clutch + 2way = lots of fun :devil:
Edited by bubba
yeah there is nothing intrinsic about a mechanical diff (1, 1.5 or 2 way) that makes it noisey. Its the "tightness" of the mechanical diff that makes the difference, and the GTR one is pretty loose from the factory. But you can tighten or loosen any mechanical diff.
the only thing that wears out in a viscous diff is the viscous coupling. which is why they start single spinning.
i got a two way n makes a loud chatter at low speeds n skips at higher speeds and holds perfectly wen driftin uphill or track lol
but yeh 2 ways make noise no matter wat but the best thing is they are LEGAL lol
SLY-dN, how are 2-ways legal? I had my viscous diff shimmed up in an attempt to find a compromise between stock and my fully clunky 2way cusco, but the shimmed stocky came back behaving EXACTLY like the cusco 2-way i had in it before!
Anyway, whilst going for inspection they noticed it skipping as the car was manouvered to the pits, and would not clear defect until it was returned stock.
As for noisiness, i think mine must be due to the alloy subframe collars. The clunking was so harsh, as someone mentioned, you have to explain to everyone who rides in the car that its "normal", "no its not broken its meant to be like that"!
Im looking for a diff now. thinking the OS superlock 1.5way. If its clunky ill throw some new stock rubber subframe bushes in. The idea of changing the bushes was to get rid of axle tramp, but with traction it still tramps anyway even with the alloy collars.
Whilst we're here, anyone like to kindly refresh the principle between 1.5 and 2 ways and the pro's cons?
thanks
its not the number of ways that make it "clunk", its the tightness of the diff.
1 way only locks on acceleration, 2 way lock on acceleration and braking, 1.5 way locks on acceleration and a little on braking. How quickly it locks (eg under brakes) is controlled by the ramps in the dif centre. 1 way looks like "|/", 2 way looks like "\/" 1.5 way is in between. In any case they will only lock when there is a change in force ie if you are just coasting no mechanical diff will clunk.
so....if you don't want to get noticed, especially with a 1 way diff, just don't put any power in as you turn, just coast around.
pros and cons....well 1 way is perfect, 2 way have become "trendy" thru fil sic drifters with the theory that the locked diff under brakes on entry make it more predictable. I don't drift so I don't know but that doesn't make sense to me a 1 way is more predictable under brakes because its not locking/unlocking as you have more or less braking.
also a tight diff will increase your understeer out of corners because the inside wheel is forced to turn at the same speed as outside wheel - this makes the car go straight on. Especially bad in a gtr with a tight front diff as well. tight 2 way diff will also increase understeer at initial turn in to the corner
i haven't read the replies, but i know a 32 GT-R with standard LSD oil in it's OEM mechanical 1.5-way diff is fine (but veerrry tail-happy in the wet), but once you change to something like the pink Redline LSD oil, it will start to bite like a mofo in anything resembling low to moderate speed corners
No fun -- could have said your mechanic put the wrong oil in it! I had lightweight shockproof in (communication breakdown) and the diff was so tight the car would actually refuse to move on full lock at low speeds!
I got to agree with the fellas saying the mech diffs with alloly subframe bushes are a bit much for the street. I haven't known any different, but some days especially city driving in traffic its just too much. I want to park it and walk home.
That and I think mine being old, 1 piece tailshaft, big clutch, stiffly sprung just adds to the pain, every little thing just gets transfered. Also I reallly dont like the 2way bit in the wet. I think 1.5 is the good compromise. Just dont have too soild rear end. They will clunk, and they will skip. Thats how they work, the clunk is it locking. The locking makes it skip.
what do you guys think of putting some brand new stock OEM subframe bushes in, instead of even pineapples?
Aim is to get rid of the harsh clunking from the diff. Has anyone gone from stock to pineapples and noticed whether pineapples make it noticably louder clunk?
I put the alloy ones in as i thought theyd be even more effective than pineapples, which they would have to be in terms of reducing subframe movement, but honestly i dont think i couldve picked the difference seat of pants once they were changed, which is why im thinking just put stock ones in.
That's a LOT easier said than done! U've gotta melt out what's left of the squashed oem bushes, press the surrounding 'ring' out and get a new set pressed in. If u'r gonna do all that, I'd put a set of noltec subframe bushes in (not just pineapples). The noltecs will be noisier than stock tho, but probably not as loud as with pineapples.
haha yeh everyone who gets in my skyline and hasnt been in a car with a 2way before thinks my car is f**ked and gonna fall apart, but yeh mine is clunky n shuddery when making tight turns, all good fun tho
I have a 2 way nismo sss in my car and got it new.
it's in an R32 gtst with a button clutch, alloy cradle bushes and rb30det torque. it clunks like a bitch accelerating and decelerating in corners. I have tried all types of fluid and now am using syntrax.
it really is too much for the street i hate driving it when cops are around. i am going to take out the alloy bushes and see if it is any better.
I lived with it in Canberra for almost a year no probs, but in Melbourne traffic it is just too much.
do not put a 2 way in a daily driven car. I am going to pull mine out when i can be arsed and set it to 1.5 way and with less preload.
I have found friction modifier also helps to a certain extent.
mine seems to clunk less when it is cold. once it warms up it clunks like a cut bastard.
having said all this when you are actually driving the car it is a pleasure.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
