Mine actually clunks and shakes the car more when cold but when it's warmed up it tends to just slip the clutches.
It is a little much for the streets and I gotta be careful around cops but pfft, I've had my cup of concrete for the day and love it ;)
  • Replies 60
mine seems to clunk less when it is cold. once it warms up it clunks like a cut bastard.
yes my cusco 2way was like that too, just a dull thud whilst cold, but after some driving, damn nasty shuddering clunks!! I ran RE55's before too, so im sure that made it even worse!
will update once the OS superlock is in. Its back ordered till end of the month tho...
i added 100ml of penrite friction modifier (lsd additive) to my diff last night after thinking a bit more about it. this was added to the castrol synthetic traxsomthingor other that everyone is using. the stuff designed for the jag with the ford friction modifier in there already.
now it is a bit smoother
Nick I can't keep up with you. You're in Melbourne now?!
For everyone reading this thread. The bushes you use will make bugger all difference. The clear answer for those who want the performance without the hassle is to do what I did. R32 GTR diff. I had a Nismo in there before and yes sometimes I loved the clunks and groans and skips and when women pushing strollers stared at me I wanted to yell out "Yes I am the f**king devil. Look away before I burn your eyes bitch." but as mentioned by others here, some days it just gets tiring.
I loved the way the Nismo locked up on the track but day to day I'm much happier with the GTR diff. I may even get it shimmed up a little one day. Flirt with the wild syde again. :P
  • 4 weeks later...
I assume the people who are experiencing noises and clunks didnt bed in their diffs?
You have to drive in a figure 8 pattern for about 20-30 mins for the plates to seat properly.This should lessen the noise,also a good LSD oil helps too.
I loved the way the Nismo locked up on the track but day to day I'm much happier with the GTR diff. I may even get it shimmed up a little one day. Flirt with the wild syde again. :banana:
what's involved in getting the GTR diff in there... did you have to change the whole cradle etc?
Took my nan to look at some shop in our local shoppn centre 2 days ago in my car (2-way diff) & she thought the rear of my car was fallling apart!
lol i love it the reactions you get are funny, ive been in maccas drive through before when a guy at the drive-thru counter says as im movin forward turning 90 degrees to the next window, ''Dude i think your diff is broken or somethin is wrong back there'' lol you get it all the time
I bedded my diff in (figure8's in the carpark next to the workshop - yes, people were looking at me funny :P) and I have have clunks/chattering. Still running the Nismo oil that came with it, am going to change the oil on Sunday when the 25 box goes in.
Try some new oil first bro, I put ls90 in on the weekend and it's gotten rid of pretty much all the clunks etc.
It used to be an absolute dog first thing in the morning that it would shake the car, now it's barely noticable, can still hear the clutches chattering but it barely shakes the car in the morning and after driving for a while it doesn't do it at all.
I went for a test drive in a r34 today and the diff was jumping at low speeds, the dealer said he can take it to a diff shop and get it loosened so it won't do it anymore, i'll go back there during the week and find out if its true.
Does the diff jumping at low speeds wreck it at all or stress out any other parts?
yeah it will hurt the rear suspension a bit over the long term, its not great for it. If you don't want the tight diff they may be able to reshim it, or you could swap it for a stock one.
You dont need to change the rear craddle.
Basicly the R200 GTR diff bolts into the exact same position that the original diff uses. Before fitting the GTR diff you need to remove the tailshaft flange from both diffs and swap them over. (GTR uses a 6 or 8 bolt from memory mounting flange and the GTS-t uses a normal 4 bolt flange.)
You need to use the GTR drive shafts and the outter hubs so the Axle spline sizes are right. The hubs bolt straight on and the original handbrake drums etc can be used no problems. The shafts are the right length and fit perfectly.
Ive got aftermarket diffs front and rear in my GTR there is no way I could drive it everyday. Turn to tightly and the whole car binds up and comes to a stop at low speeds.
Edited by Risking
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • I think you know exactly who I mean.
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
