Put Lewis in A Jordan at Spa, have him qualify 7th, send him for a year to drive with Force India, then I will shut up about Lewis..
Untill then, I'll proudly repesent the unsilent and unrepentant majority of Lewis loathers!
  • Replies 3.9k
Posted Images
Not sure why anyone would watch sport willing someone to fail.
Its only natural for me. I have never won anything in my life without the other blke making a complete breakfast of it so i got a chance. So now as a spectator my boy cant get up unless others fail...we need about 8 to 16 cars to fail if Webber or Bourdais are going to win in Brazil :P
Its only natural for me. I have never won anything in my life without the other blke making a complete breakfast of it so i got a chance. So now as a spectator my boy cant get up unless others fail...we need about 8 to 16 cars to fail if Webber or Bourdais are going to win in Brazil :(
well you never know, give lewis a call, he'll arrange something.
5 championships in 8 years leading up to his F1 career, finishing 2nd in his rookie season in F1 equaling the points of the reigning world champion in the same car...I think he's proven his worth enough not to have to drive for a team like Force India.
Only an envious idiot (yes, that means you) would criticise him because he hasn't driven for a lower rung team in F1.
Ferrari are doing a bit of dick swinging by saying standard engines means they'll take their bat and ball and go home, but then I think that's the only language Bernie understands since everything he says is phrased the same way.
Standard engines would be a terrible move.
Yeh, itll turn F1 into A1 x2.
And here's why the standard engines wont happen:
http://www.formula1.com/news/headlines/2008/10/8595.html
Personally I think that standardising anything in f1 is nothing short of stupid
just wondering how much more smug and arrogant he's going to be if he wins.
realistically i think he will do it (he only needs to come 5th right?), but deep down i want him to choke like last year just so he can work his way up the ladder like everyone else.
Season finale race start 3:30am monday morning :\
looks like i'll go to bed early and get up for it...
looks like I'll be taking the monday off, 4 day weekend. I was gonna work the monday, but not gonna miss the GP so a day off it is.
Rotisseries! BRAP BRAP BRAP!
also, I'm seriously considering having Tuesday off, or coming in at about 1 or something :D
Its on sunday night/monday morning...us victorians get the tuesday off for the cup anyway :)
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
