  • Replies 171
i wonder if the new GT-R's roof is tall enough to clear your noggin danny? You're as good a test of interior design comfort as Jeremy Clarkson and his neanderthal body.
it clears my noggin. and I'm 6ft2" of man love. :banana:
does it clear your gigantic ass bones?
*ZING*
i keed i keed.
can't doughnut king just change to like an "icing sugar theme" so they don't have to paint that beast pink?
i refuse to eat at donut king after this thread
you're looking at this the wrong way humz. If donut king hadn't put up their hard earned as a deposit 12 months ago there wouldn't be one on the docks now. certainly will be at least 12 months before nissan bring any in.
So good on them I say, stuff KK, support an australian company that likes GTRs :banana:
maybe just leave it white and put big DK decals on it? salvage some resale out of it!
Benny from southern/autosport does vinyl like that we stickered up that grey z tune(i think it was?) mockup at autosalon some years ago.
Well after going to see it, i can tell you that from the inspection i had its in dire need of a good wash.
Also the front grill looks great, but stonechips wont be its friend
One thing that got me thinking - its build number isnt as low as you would expect!
Donkey Kong bought the car? Dammm Nintendo bought it!! :D
Drift King?
Donut King .... mmm Wonder if Krispy Kreme will buy one too? or maybe DCM?
hmmmmmms
lol, starbucks so shoulda bought it, damn 6 dollar coffees..
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
