Nick, I'll be at the gym from 11am on Sunday, till late afternoon. Have a new guy lifting that benched 175kg last night in my gym.
He's a bodybuilder that recently won his first IFBB show. He is 173cm and 94kg. He is odd in that he squats 190kg x 6, deadlifts 250kg and benches 175kg.
Most BB dont train that heavy. He is very thick. I know a couple of the guys that compete against him, one NEVER deadlifts and only does 1/2 squats
Will be interesting to see how Michael goes in a comp, I reckon he'll go over 600kg first time out.
fck me... mental note, don't lift right after that guy!
damn I love a good burger... might actually have to clean the R... actually who am I kidding, that won't happen lol
Easy mistake to make given Dezz's physique :P
:wub:
In all honesty though, you have far more potential physique wise than I do..
Watched one of the resident BB'ers at my gym squat 300kg for reps the other day...deep.
Impressive stuff
So I'm going to be a test dummy and buy some of this albuterex just to see if its anything worthwhile.
My friend Is currently using it and he swears by it that his able to get so much more out of a workout then normal and his shredding as well
I daresay its not either.
But fark its worth a try and then I can actually tell people yes or no.
Rather then read off forums where people say its crap but they took like 4 scoops and went to hospital.
The net is littered with people saying its bad for you but they are taking more then what’s recommended
Military press is with a barbell behind the neck isn't it, or am I thinking of something else?
I never do it behind the neck, I have been told by a few trainer it's actually bad for you
how would that work though? the thought of it is kinda weird :yes:
No, that is a seated overhead dumbbell press, also known as the Arnold press in some circles.
"Military" means the exercise is done standing.
Edited by GHOSTrun
Because it's just a shit ton of caffeine and incredibly dangerous... you may as well just down 4 red bulls then hit a session.
Also, FIGJAM, you seem to be very interested in steroids lol. Why do you seem to have so much self pressure to get huge?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
