haha no pressure. I actually have a friend who just did his first cycle, has a week left and put on about 8kgs. We think he will drop bit of that weight cause he said he put most of it on in a week or two.. was interested in how much Vspec managed to keep.
I cant really risk roids due to having a heart condition called ARVD especially if all I was hoping to gain and manage to keep is like 4-5kg, which is a good gain i realise but the risk to the reward not really there.
Too many downsides to the roids that I could afford haha!
Doing it natural will be far more satisfying in the long term imo
On another note, I did the seated behind the neck press for the first time today. I liked it, managed to push out 5 sets of 8 (only made 7 on the last set) on what I think was 60kg. I think I'll alternate between it and dumbell shoulder press from now on!
Edited by Mitcho_7
Military = standing press, whether behind neck or not, to my knowledge. It's also traditionally done with a barbell. If you're doing it standing, make sure your knees are slightly bent to preserve your back and put one foot forward.
I never do it behind the neck, I have been told by a few trainer it's actually bad for you
Yeah...f**k that. They say the same about lat pulldown. It might be riskier for injury, but I have been doing both exercises behind neck for many years with no adverse results. You do need to have a good technique and build up flexibility to pull off a decent range of motion (i.e. touching neck), though.
I like behind neck because it isolates the delts and you can't really "cheat" by involving your chest.
Good advise Birds, I'll keep that in mind.
What are you guys doing in terms of barbell military press? I'm finishing up on 55kg barbell.
(mind you I'm Asian, 6 ft, 86kg, can't get any stronger.. been plateauing for ages)
Military behind neck and touching it, 40kg x 10 on the first three sets, 50kg x 10 on the last three. 79kg 6'3
What sort of body fat do you estimate Johnny?
I am not too sure to be honest, never really looked into that. I am bigger than all my asian mates, and on a good day can bench 110kg with some spotting.
I find that I can't get any stronger, and if I start eating a tad less I shrink. I'm a tad flabby, like not defined.
Probably 20% body fat?
Oh, so Birds is a guy, cheers Mitch
Sorry about that Birds, odd username
All good brother, had the nickname since I was young and my avatar doesn't help :)
That being said, I know a girl who is about 6'5 and her boyfriend is nearly 7' lol.
I think if you doing any form of resistance training you're going to get gains from it in the long term. But tailoring that program to suit your goal is what will yield the improvements you are most keen to see.
That has been one of the smartest posts i've seen on here.
Crossfit works, cardio works, powerlifting works, weightlifting works, bodybuilding works...it all works. Just depends what YOU need from it.
Does frequent masturbation work?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
