Theoretically, 2.5kg each week is going to be over 60kg in 6 months. Assuming he can pull off the increase each week, that'll be 200kg for reps midway during this year...
P.S. catching you in deads Troy. I pulled 150 the other day, after squats and deads. I reckon fresh I might give you a run :P
Because Birds
This.
I have been considering putting squats on my push day...where they technically belong...to give deads a bit more potential. Problem is, after all the chest exercises on push day, I'm utterly sapped of energy.
Truth be told, I added deads and squats to my routine at the same time, so always just did them one after the other on the same day. There's interference, but I'm still progressing in both exercises, so maybe when I plateau or get sick of fainting I'll swap one over.
My deadlift is currently at 140kg for 5 reps.
Not great, but not doing too bad either.
Its going up steadily with your 5x5 program
Are bench and squats moving at a similar pace?
on another note, i have decided i enjoy doing back workouts the most. Nothing better than rows, deadlifts and weighted chins
Edited by Mitcho_7
Bench is being stubborn, but I'm incorporating heavy negatives on the smith machine to work through my sticking point.
Squats are slowing in progression, sitting on 92.5kg full depth, will probably try for 95 tonight.
Don't forget the forearm pump from back workouts too Troy!
so my Mrs bought me an Inzer lever belt, Tshirt and knee wraps for Christmas... Thanks to Markos! lol
squatted with the belt once before I left for Vic Harbour with a bunch of mates for 2 weeks of sun, beer, food, beer, sand and... beer
got back yesterday, hit the gym today... oh dear..
one week off is great every few months... two weeks off? not so much
What gym Nick? 2 weeks is ok a couple times a year, but its the 2 weeks Plus the beer that does it...
Not enjoying pasta of late, feel so blah afterwards.....
Big workout tomorrow; bribing my boys to behave in the small kids room with a reward of a cinema night - haven't gone in there yet with the kids in tow.
155 as of tonight!
And my gym has chalk now...wtf Genesis...
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
