Sorry but that still doesn't tell me why.
Don't apologise...
Not taking anything away from his effort, but look what happened when Ghosty reached the end of his rep range...his back and core wobbled and he stumbled around (forcing legs out of their previously locked position) trying to catch the last rep. A less...injury prone...way to standing overhead press, is one leg in front of the other and knees slightly bent. Done properly, you'll never move around like that.
Don't apologise...
I'm not apologising it's just a figure of speech.
Splitting your legs may take some pressure off your back as it stops you from leaning back as much. However, this has nothing to do with knees being locked out or not.
And leaning back has nothing to do with the exercise, it has to do with the person. If you are pressing overhead and start to struggle, you can either stop, start push pressing, and/or lean back to try and reduce the rom. Just don't lean back stupidly and you'll be fine.
I personally think flexing your quads gets more muscle fibres activated and provides a more stable base and core. And to do this your knees have to be locked out.
And to finish, the exercise 'military press' is done with legs locked out. If you are doing anything else you are not doing a military press.
Don't apologise...
But that was due to bad technique/overdoing it. Not because of the intended way to do it.
Edit: husky got me.
Edited by jangles
I'm not talking about him leaning back a bit, that's fine. I'm talking about the wobble in his midsection that is a result of pushing the set til failure and his back/core being the first part to give way at the sign of a struggle. With straight legs, your back and core take the full brunt of it, as that's the only place flex can occur. Bending knees slightly, gives you more control over the movement; allows you to use your leg muscles to maintain a straight back and regulate/reduce/counter wobbles on the Y axis when you start to struggle.
As for military press defined, in it's strictest sense I'd agree with you...but people do it sitting down and call it that, so as long as you're not driving with the legs when splitting, I don't see the harm in a slight variation to prevent injury when lifting heavy.
The military press/strict press was a lift that was done at the olympics. These guys were pushing 200kg's, and they had to have their legs locked.
Doesn't matter what people do or what people call things, the military press is done standing, with legs locked. It's not made up gym rules, it was a sanctioned olympic lift.
If you want to military press, stand up, knees locked, and don't bend your back too far. If you feel you are straining your back, stop the exercises and/or drop the weight. Work on your core strength and lower back strength.
If you just want to overhead press, then doing whatever way you want. Bent knees, split legs, sitting down, upside down....who cares.
I said I agreed with you about the definition of it? I just don't care if people think what I'm doing isn't military press, I'd rather save my back. I'm doing it for the exercise, not the title. If you want to talk semantics, I originally referred to bending the knees during overhead press movements, not military press specifically.
Anywho, I've already broken my rule of one argument + rebuttal, so time for me to let this one go.
I'd rather strengthen my back.
Change the way you think Birds ;), if something is weak then make it strong, don't avoid it.
/gah simon beat me to it
Edited by GHOSTrun
Current stack:
Synthol & some horse hormones that I got from some bloke who wanted to keep his name secret so he called himself chestbrah.
Seriously, eat clen and tren hard. Ty men.
Strong post to join date
Strong AVI
Strong username
strong everything
This guy.... uses every damn quote that annoys me from Facebook pages
Edited by Dani Boi
From Facebook pages...? L2internet my friend. I loved these quote UNTIL I saw them on Facebook, at which point all the little social media faggots cancer ruined them.
I'm sorry for offending you Tom.
Strong AVI
Strong username
strong everything
hehe ty men.
Some people just want to see the world burn. I'd agree with you there though, almost everything from 4chan (/fit/) included it's hilarious. You would NEVER hear anyone talk about "epic" things or "memes" circa 07.
Yes your bulging discs are doing a great job of that. Strengthening doesn't fix bad form, correcting with proper technique does. I'm not avoiding any weakness here...the back and core get worked just as much in my method, only less susceptible to injury because it's a stricter movement.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
