A lot of greatly varying opinions lol
I stick to around 2mins for the compound stuff, and that's all I do with weights, the rest of the work is stretching/physio/back stuff that's BW. Planks, cat camels, rising cobra things all that manly stuff.
I have so many posterior chain exercises to do from my physio I cant keep up lol
Physio appt Friday and I need to decide if I want a referral for an exercise physiologist or a sports science doctor, as my physio said she can't help me anymore.
What would you choose?
No idea about either sorry.
I've just been doing a bit of reading picking out exercises and going for it.
Everybody with my particular issue seems to find different things work, the common denominator is it takes everyone a decent amount of time to find it and then see results.
All this means imo is that you aren't ready for that weight yet. You've over come a mental barrier because you feel better for 'lifting that weight' 'getting that number' but if you waited a consistent couple of weeks, it would of became an 'easy' clean movement acceptable to the true form. Submaximal training is a powerful thing.
Submaximal is powerful, but so are big singles, which is how I've broken through most plateaus for this movement.
I can remember having average form on a 170kg 1RM; I likely hitched it up at the time and it would have taken 10 seconds to lock out. But my last 1RM was 195kg (from memory) and now I'm pulling 5 of 170kg in quick succession, with no hitching.
IMO, outside of competition rules etc., if you aren't rounding your back on a max lift, it's probably not your max lift. I don't recommend everyone train that way, but it's always worked for me and my back has never felt better. Waiting for the weight that tells me it's not the right way to lift. I've failed a weight before and the worst that happens is a dented ego.
I would choose neither for now, given you can train lightly again now without pain. Your injury is on the mend and you'll only be paying for another opinion that you need to rest it.
For all the strong opinions and somewhat positive self image Bird's has, I do think that if nothing else, he knows his body well enough to make his own calls on what works for him.
We all respond differently to different training methods. Find what works for you and go with that.
As for the back rounding stuff, I won't enter into that convo, if I can't squat and DL anything remotely deent without busting myself in half, I have no place lecturing others :)
Yeah that is right, people know their body limits. but hitching is hitching and it is poor practice whether it works for him or not.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
