Deads are coming along again after a deload, only warm up weight for some but on my last 2 sets today I managed 5 x 150kg then 3 X 160kg, I should have only gone to 155kg and will drop my last set to 155kg next time.
I did manage a good 270kg from the top of the knee to lock out on my last set of 5 x 1 of them though, started at 250kg and went up by 5, I did make some noise though.
I am going to rotate between 3 x 8 deficit and 5 x 1 knee height to try and keep it slowly going up.
Sorted out all those injuries that prevent you from progressing yet Dan?
Is this supposed to be a thinly veiled jab somehow? Despite me having already said I wouldn't be lecturing anyone based on having injured myself with poor form/mechanics? If so, lol
100kg x 7 on bench, I think that's a pb for me!
Nice job dude. I'm slowly bringing up that 3rd incline set, started out at 54kg and the bar was very hard to control, now got about 75 on it and managing 10 reps (just) after doing 10 then 8 at of flat something just over 100, think it's like 102.5 or so.
Thinking I might drop the second flat bench set and swap in another incline set as I don't want too big man titties (I have cut eating also to assist until I can do some decent cardio again).
Edited by ActionDan
Mine are big enough now. I don't want them to be any bigger to make it easier when my metabolism slows more and I find it harder to change weight as easy.
My thinking is that as I get older I'll slowly lean off a bit over time to avoid sag if possible lol
Hahah, that's my thinking too, but I more so mean I'll step down in weights and move more into cardio as I get older. For that leaner less bulky look and hopefully that will help keep me tight like a tiger.
What's a better game plan then, legit question.
My theory is if the muscle is a little smaller through lighter weights higher reps and my body fat is lower through cardio and diet I should be OK.
I know muscle itself doesn't sag but the connective tissues do. Less weight on those would help.
Less fat is always going to help.
All old people sag - fact. No training will avoid that. Even skinny low fat triathlete oldies sag. You either get lucky or you don't.
Look at Stallone...as roided up as he is, he's in top nick for a man in his 60s...very defined...but you can see the age; you can see the sag. Nothing can be done. Deal wit it.
Keep the fat off and that's the best you can do.
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
