Yeah I was trying it with the clean grip - I've never done cleans or any other Olympic lifts before either!
I'll try the arms crossed one, I thought it was bad for you though. Failing that, I'll invest in some straps, since the hand placement isn't an important part of the movement
Use a Smith machine to figure out which grip works for you. I'm going to start front squats soon and that's what I plan on doing first.
No way I'm going to try arms crossed with a barbell first time round. Might kill someone
Safety bar squats are somewhat similar to front squats in that the weight is out the front of you a bit. I am doing them at the moment because I have niggling ac joint issue and front squating with the bar on it in the rack position hurts.
Well an empty still weighs 20kgs and isn't restrained, so if you don't have it sitting right and it falls you could injure yourself or others I guess (and look like the tard that dropped a bar..)
Smith machine with 10 a side to start, once I get familiar with it move up to barbell.
Front squat focuses on the quad right?
Also, what program do you suggest to really stimulate calf growth? I'm finding that the arches of my feet start going before my calves so not getting the most out of it. I'm considering taking skipping back up to develop some conditioning on rest days and then high volume sets on leg day.
Comments?
another technique to stretch your arms out to improve front squats is:
assume the front squat position with arms under bar and elbows forward
have friend stand with their shoulders under your arms and slowly stand up
i get my mates to do it, main drawback is theyre both 6ft6 and im 5ft 10
sounds very broke back mountain.
which part is difficult boz?
Elbows up?
thoracic extension of the upper back?
shoulders not able to come forward enough?
video it
all fingers under is fine if you can.
but it requires more wrist flexibility.
the first 2 fingers makes it easier,
They are not there to hold the bar really.. just to anchor your hands somewhere so you can push the elbows UP.
and yes..
right up in to your throat.
I get my fingers where I want them, then the feet under, then swing one arm under, then the other as I put my head right back so the bar is right up against the part of my throat and clavicle meet.. then bring my head down.
as you stand up and have elbows up, the bar ends up sitting on your front delts rather than the clavicle.
then it's a big breath in, chest/elbows up, back arched, and squat down between the heels.
This shows where I mean by on the throat/clavicle.. ignore that his hands are not on the bar.
and what I mean by 2 fingers..
Edited by TTT
Its defs a fine line between cutting off air supply/blood flow and finding the right spot for the bar. If you find it hard to keep elbows up, wait til you start squatting with it.
I get just as mucg of an upper back workout as legs doing them.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
