Yeah I was trying it with the clean grip - I've never done cleans or any other Olympic lifts before either!
I'll try the arms crossed one, I thought it was bad for you though. Failing that, I'll invest in some straps, since the hand placement isn't an important part of the movement
Use a Smith machine to figure out which grip works for you. I'm going to start front squats soon and that's what I plan on doing first.
No way I'm going to try arms crossed with a barbell first time round. Might kill someone
Safety bar squats are somewhat similar to front squats in that the weight is out the front of you a bit. I am doing them at the moment because I have niggling ac joint issue and front squating with the bar on it in the rack position hurts.
Well an empty still weighs 20kgs and isn't restrained, so if you don't have it sitting right and it falls you could injure yourself or others I guess (and look like the tard that dropped a bar..)
Smith machine with 10 a side to start, once I get familiar with it move up to barbell.
Front squat focuses on the quad right?
Also, what program do you suggest to really stimulate calf growth? I'm finding that the arches of my feet start going before my calves so not getting the most out of it. I'm considering taking skipping back up to develop some conditioning on rest days and then high volume sets on leg day.
Comments?
another technique to stretch your arms out to improve front squats is:
assume the front squat position with arms under bar and elbows forward
have friend stand with their shoulders under your arms and slowly stand up
i get my mates to do it, main drawback is theyre both 6ft6 and im 5ft 10
sounds very broke back mountain.
which part is difficult boz?
Elbows up?
thoracic extension of the upper back?
shoulders not able to come forward enough?
video it
all fingers under is fine if you can.
but it requires more wrist flexibility.
the first 2 fingers makes it easier,
They are not there to hold the bar really.. just to anchor your hands somewhere so you can push the elbows UP.
and yes..
right up in to your throat.
I get my fingers where I want them, then the feet under, then swing one arm under, then the other as I put my head right back so the bar is right up against the part of my throat and clavicle meet.. then bring my head down.
as you stand up and have elbows up, the bar ends up sitting on your front delts rather than the clavicle.
then it's a big breath in, chest/elbows up, back arched, and squat down between the heels.
This shows where I mean by on the throat/clavicle.. ignore that his hands are not on the bar.
and what I mean by 2 fingers..
Edited by TTT
Its defs a fine line between cutting off air supply/blood flow and finding the right spot for the bar. If you find it hard to keep elbows up, wait til you start squatting with it.
I get just as mucg of an upper back workout as legs doing them.
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
    • I'm going to guess, likely headunit, and the twin cable likely went to an amp as a remote turn on feed.
