Is the image flickering on the M35 screen in NTSC or just distorted ? when you change it to PAL from NTSC does the flicker rate and colour change ?
PS. depending on numbers I may be able to get some more Asuka tuners in the next few months, I won't do a group buy as such, but if anyone is interested flick me a PM for details.
  • Replies 204
Decided to give this a try once more.. fixed my short antenna cable problems..
Using an external House Tv i have it set on Pal and things are great..
switch it back over to NTSC the tv in the M35 still does not work properly. image is all over the place and unreadable at times.
Aspect ratio a problem? I've tried every setting i can possibly try on the unit.
Cant seem to get the tv working at all. i am guessing its a problem with my M35's tv?? could that box on the previous page be causing problems??
Andrew if you around my area give me a call and I'll have a look for you...I am home most nights
Hi Andrew
If Craig can not find the right settings, let me know I have a few spares available to test it on and we could swap out various parts to fix the problem.
Cheers
Andy
Yer that image of my Navi screen is it going from side across pretty fast. when on pal it goes in all directions fast. similar with auto settings too..
always in black white.. sometimes maybe a hint of colour.
Andy, Craig. No problems! would be happy to get this up and going soon! if its not just some simple settings somewhere i'll swing around :cheers:
Sorry Mr. Chook I am relatively new to SAU so I am unable to send to you PM (some nonsense about needing a minimum 10 posts first). Anyways, I am absolutely clueless about installing the tuner, is there anyone in Sydney who you could recommend to assist me?
Regards,
Roullos
Regards,
Roullos
Hi Mark
When you get the tuner let me know and I will give you a hand with the install.
Cheers
Andy
  • 4 weeks later...
Hey guys,
I just bought the Asuka TV Tuner off Chook.
I want it installed:)
I am wondering of there is anyone in Sydney who has done this install on their V35 and if would be willing to help me out sometime this week? (Willing to pay)
Otherwise do you know of a place who has done your Asuka install?
I'll give you a hand.......bit rusty as I did mine 2 years ago but I am sure between the both of us we can work it out.
If you interested PM me.
cheers
Craig
  • 1 month later...
Hey guys,
I got the screen override thing from Chris! Just wondering has anyone installed it and got instructions for it? I know you have to take the dash off and stuff but not sure where to plug it in:)
Regards,
It plugs into the back of the dvd rom, so you will need to remove it from the dash unless you can get the harness out without taking it out.
Towards the midde of the unit there are 2 harnesses plugged in. one grey, one white. The white one which is on the drivers side is removed and you new harness is plugged in to the back of the dvd rom and the original harness plugs into your interceptor harness.
Hope that helps.
Cheers
Andy
Hope that helps.
Cheers
Andy
Hi Andy,
Thanks for that. But what about the other wires? I have a red wire which isnt liked to anything and also a black wire with a gold clip attached to it. Are these just left there?
Regards,
looks like they changed the design slightly.
black wire - put that under a screw
red wire - lt grn on wht plug (this is in the corner of the plug with two yellow wires.)
plug the rest in.
this is an auto reset one so when you turn the key off it turns off..
plug the rest in.
Hi Chris,
Thanks for that.
With the red one, what do you exactly mean?
Also there is some screw thing as well in the pack, its red and grey with both sides you can open. Do I do anything with this?
regards,
Hey Chris,
All good, after I spoke to you on the phone I decided to try the light green one as per your instructions haha instead of using the dark green one! But yeh all works fine. Everytime you turn the car off, you have the press the button for the override:)
Thanks Chris and Andy for your help:)
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
