spotted white R32 gtst on Morphett rd and plew Ave parked in the power station driveway look like its stolen just putting it up here if anyone missing r32
Not stolen (I Hope) - where we park when all the parks at our business (adjacent to the Switchyard) when clients are in for meetings and car spaces run out. Sometimes you'll see upto 6 cars crammed into that little space lol. Good spot!
got sandwedged between 2 stageas at the hub petrol station in my daily tonight. one was white with nice kit and r34 gtr rims with dark tint, other was silver and stock with a spoiler. both female drivers
That was me in the white stag that didn't happen to b u in the Nx was it?i seem to spot that Silver stag fairly often =)
Edited by Stageas2
oh thank god. looked like it was stolen. good to know its safe ;)
definately was me, in my daily hurbing around. good to finally see some members down south as i find them very hard to spot =P
Few cars tonight amongst the Hills/Blackwood - Dark colored R33 on Clarendon-Blackwood road, R31 doing donut/burnout up on the North/South Summit intersection near the pub (lucky didn't get your number plate), R32 GT-R (Silver) near Hove area on Lonsdale Highway headed towards Bay.
Spotted a Black R34 four door with dent in rear boot lid and light blue R33 with white 5 spoke rims in Whyalla. Good to see imports out in the country.
Brad, that 34 4 door MIGHT be Andrews old one, i saw it when i was up there a couple of years back. Theres plenty out there, and its fair dedication when their only dyno tune place is at Warnertown (near Pirie) LOL
saw a r33 s2 in silver with led tail lights on black road coming off main road at around 6-615ish tonight. didnt really notice it till i saw the led tail lights
plus i think i keep seeing madaz around my work at richmond on farnham road around 430ish?
Edited by buzz350
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
