Just picked up a 32gtr, looking to do the engine, gearbox and diff oils pretty soon.
leaning towards smurfsblood for the gearbox (crunching into 5th also when shifting at speed), but not sure whether it is appropriate to run the same oil for the front/rear diffs.
Also is 10w40 semi synth ok for a rebuilt motor? oil will be changed every 7500kms and primarily street use.
  • 3 weeks later...
  • 2 months later...
Just noticed that redline recommends 80w140 for the rear diff and lightweight for the front diff. Anyone had any issues with this set up?
http://www.redlineoil.com.au/oil-finder-detail.asp?CategoryID=3642&ProductID=7592
80w140 just causes a bit of chattering when cold. That's about it. Been running it for 2 years with no issue at all.
  • 3 months later...
Been reading through all these pages and can't find a straight answer for my questions
I have a er34 awd manual
Gearbox oil-?
Transfer case-trasnmax z?
Rear diff oil-? Visious it think
Front diff oil-?
Attesa pump-trasnmax z?
Thank you to anyone that can clear things up
And! Just wondering if all my running gear and things are off a stagea? Might be able to find things easier.
Edited by BabyZ
Your gtfour is a 5 speed correct?
If it is not crunchy then put in a normal gb fluid as recommended in one of these pages.
Use lsd fluid for your rear diff (not needed for front but you might as well because it takes a bees dick worth of fluid)
Transmax z for remainder.
Just presume your car is a gtr then take advice from here.
I have read through this thread several times, and still end up confused on what product of oil i need to put in my GTR's rear/front diff's and transfer case...
Can somebody just tell me exactly what i need to buy from my local supercheap auto/auto barn/repco!
I did my Gearbox oil the other week, and used Castrol VMX-M. Seems all good to far, and shifts a bit smoother then the old oil that was in there!
Please. Somebody, just tell me what i need to buy......!
Thanks, I have the transmix z. So that's the attesa and transfercase out of the way
(one shop in town had it)
And they recommend castrol axle EPX 80-90 for the front and rear? Haven't opened it yet because I feel sus about it. And also they said that I don't need to change the gearbox fluid..... So that makes me think they don't know. Just going off that fluids chat on the computer. And I don't really bother because the aren't and er34 gt-fours listed... Then he told me that my car is rwd.. But yeah, it is manual. Iv had it for 7 years. It's not crunching into gears, it's just getting hard to select reverse and 1st when cold. Think it could be all factory fluid. Because when I first got it I was the second owner in Oz the previous owner had it for a year, and when I first got it, it had a big ass blue oil filter with Japanese over it. Old dirty spark plugs.
Going off topic
  • 2 years later...
On 07/09/2017 at 8:21 PM, danny14 said:
Hey guys who uses redline trans oil and what's the difference between the syn trans Castrol
I use Redline MT90 because its an actual GL-4 spec lube instead of Castrol and most other brands which are GL-5.
The Nissan boxes are supposed to use a GL-4 although most people use GL-5, which apparently isn't good for the brass synchro gears.
Ok cheers for that what about penrite pro gear oil
  • 1 month later...
  • 10 months later...
On 9/6/2018 at 12:21 PM, danny14 said:
On 10/21/2017 at 7:42 PM, Torques said:
I recently changed over to the OEM gearbox oil.
The gear changes were never as smooth before, I'm very happy with that oil and it's not expensive either.
You mean Nissan oem oil?
Hi there,
Yes, the standard Nissan gearbox oil ..
NISSAN MT-XZ GEAR OIL PASSENGER VEHICLES SAE 75W-80 KE91699932
https://www.ebay.co.uk/itm/GENUINE-NISSAN-MT-XZ-GEAR-OIL-PASSENGER-VEHICLES-KE91699932-1-LITRE/163151777634?epid=1315215982&hash=item25fc9a8f62:g:K-QAAOSwAldZ0lte
Hi there,
Ok cheers. I recently changed my box and out mt-90 redline in it I believe now that this may be the incorrect oil. Pushing 490kw through stock box also ahhhhhh
3 minutes ago, danny14 said:
10 minutes ago, Torques said:
Hi there,
No worries ... 490KW .... that will do :) Good man!
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
