I know one thing for sure. The car has the best inner guards ever ! They alone make it the best GTR in the country :P (seriously, they are trick)
A vote for AUSSIE ENGINEERING!!!!
Actually, this car is a pin up for a locally developed GTR. Velo seats, Harrop brakes, V8 Supercar rear wing when at the track....there seems to be a trend to stay away from the normal Japanese parts bin?!?!?!?!?!?
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660201
  • Replies 241
another good one Roy...time after time Croydon's have been sent cars from XXXX (insert well known japanese tuning house) by Autostyle and a few other importers.... only for them to be not only poorly set-up but tuned like a dogs breky. People please take a good note of what has been said here. Yes the Japanese do things well, but just because XXXX has built the car does not mean its the perfect car. In most instances...far from it. A handful of Aussie tuners/builders can do it better than them...id match Racepace/Croydon/Godzilla/Berry-Newman teams against most of what Japan has to offer. We already proved this 15 years ago when Gibson Motorsport was the world leader. Nismo asked them not to bring their cars over to Japan to compete due to the fear of being humiliated.
Torque graph Ben ?
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660313
Nice work Gary. I'm pretty sure a lot of that is wrong though. Except for the last bit.
But then the only person who really knows is the big fella. Even then I'm not 100% convinced he even remembers what has been done. Because every time he's done something to the car I've returned to find he's pulled it all apart again. LOL
There are only a few options to achieving 2.95 litres, you are limited in the bore size. Being 86 mm standard, 86.5 mm oversize, normally used for ensuring straight and parrallel bores and 87 mm about as big as you want to go. Although there are few alive at 87.5 mm, but that an unnecessary risk that I wouldn't take. From there the stroke is easy to work out, simple high school maths. Once you know the stroke and that it has an RB26 block (tall or short), then the rod length is again a simple subtraction. Getting short custom rods made is expensive and unnecessary as you can more easily and cheaply select the gudgeon pin height. Such that the piston doesn't hit the spark plug. Plus the rod stroke ratio is pretty terrible anyway and shorter rods would just make it worse. Up to here it's just mathematics, the camshaft timing is the real tricky part, it depends on the valve sizes and porting, So my guess (272/280) is simply based on what my past RB30DET power curves look like, hence it is a 100% guess.
Lots of fun for all
Cheers
Gary
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660353
Lots of fun for all
Cheers
Gary
I reckon you have almost got it sussed...except for the turbo's...even a 2.9 wont bring RS's on like that. Gav's 2.8 is proof of that.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660371
they may with some clever head work/manifolding
im with SK on this one, i cant see it being RB30 based, i rkn RB26 block with a mix-n-match storker kit, with at least one of the 3 components being custom, most lilely pistons or rods. cams would be big, my guess would be around the 256/64 mark, a little smaller than what SK said but with a smooth 900rpm idle, even with the ebst tuning getting cams like that to idle at 900 would be a stretch (i think so anyway, i have nowhere near the experience of SK)
i reckon all that low down power and torque is from manifolding and headwork, thats the 'secret' area.
so is this gonna be revealed at all anyway, or are we just stabbing in the dark for no reason? c'mon.... at least give us a hint? tell us whose closest to the real deal? please...... :rofl:
Edited by VB-
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660533
Hey guys,
I really don't mind sharing the shortblock specs, as I'm fairly sure I've posted details on here a while back.
Bore is 86mm
Stroke is 84mm
Rods are SR20
Its a liner/spacer-plate RB26 block (ala OS RB30), 20mm taller than std.
cheers,
Ben
Im amazed there is an 86mm bore RB26 block left in the country :rofl:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660729
Haha - that was the bit I knew. (Sorry Gary but it wasn't my place to say exactly what was wrong).
I also know what the turbo's are unless he changed them again and they aren't GT-RS (although he did test them I'm pretty sure).
The one thing I've found with Ben is you take what you think you know to be right and discard it because he seems to get great results by doing things completely different to everyone else.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3660980
:) ummm steve. spun bearing.... oily car. remember that day...... teeheee.
lol yeah i remember, but i got back out there as the bearing hadnt quite spun yet :banana:
In the end it didnt spin anyway ;)
I thought you would remind me of that day
I know one thing for sure. The car has the best inner guards ever ! They alone make it the best GTR in the country :D (seriously, they are trick)
Pics/details please?
Garrett -10's?
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/5/#findComment-3661514
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
