Trust The Yanks To Pull One Apart...
So what's the first thing you do with your new R35 GT-R. Take it to the track? Do laps down George st?
Apparently they pull things apart in the US... Don't really know why yet...
http://www.stillensucks.com/kevin/kevinsr35pics/
edit: Anyway the reason these guys pulled the engines out is to import them into California. This is apparently the only way to do it with the car being reassembled once it gets there.
https://www.sau.com.au/forums/topic/207876-trust-the-yanks-to-pull-one-apart/
  • Replies 62
Actually..
do yanks have to have their new cars in pieces for import?? or a car like this in pieces for import?
i remember talking to someone saying that engines and gearboxes have to be out of cars to import...?
Looking at the peice of kit in the background they'll have something good in mind...
It could be worse... when I opened this thread I thought it was going to be yanks fitting airbags, some 24" chromies and a 42" plasma screen or something....
Actually..
This is possibly what they did.
If Stillen is doing the work, you can bet the end result will be phenomenal
I'm betting the engine was removed so it could be hooked up to an engine dyno (after some kind of rebuild?) for some proper tuning work
considering the pics are on stillensucks.com I think it's pretty unlikely stillen have anything to do with this car... :cool:
The US has money, and they've been salivating over the GT-R for ages.
It wouldn't surprise me if companies over there brought the car in to pull apart so they could start developing aftermarket parts for it...especially for the powertrain. If not Stillen, then you still have other companies like Jim Wolf Technology that specialise in Nissans.
The best way to learn how something mechanical works, is to pull it apart.
Remember when you use to play with lego. You would build something, then pull it apart and put it back together again.
Did a seacrh on J connect spec, the sticker on the rear of the black car
The cars have been imported for aftermarket parts development
http://www.autoblog.com/2008/02/16/j-spec-...-rs-in-the-usa/
http://blogs.cobbtuning.com/?p=194
They probably took it apart for the same reason Mines, HKS and other tuning houses have. Just a guess!
you mean that Mines, HKS, etc don't just get a bunch of guys to stand around the car looking at it and guessing what sort of cams, etc are in the motor? they actually pull it apart to look? so that is where i have been going wrong, LOL.
LOL at anyone thinking the americans are stupid. i bet there are jap tuning companies with a gtr stripped bare.
I think you'll find that the Jap's are taking the more sane route of basic upgrades to extract what they can from standard and then figuring out their options from there. Pulling the engine straight out when there is 0 development hours spent on the car in one piece is not something i would do personally.
Anyway the reason these guys pulled the engines out is to import them across the border into Canada from the US. This is apparently the only way to do it with the car being reassembled once it gets to Canada.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
