When balancing the crank, my machine shop drilled holes in the the counter weight rather than grinding off material as Twoogle has done. Is one way better than the other?
Gav our balancer has done both grinding and drilling. Tiny little drill marks were on most of the counterweights as well as the large ones from the factory. Grinding is generally done when material near the big end journal needs removing and drilling is done when removal of material from the counterweight has to go.
Hey Paul how do u rate the cp ring sets? i pulled my motor down after the initial dyno tune to check pistons etc and noticed a couple of the ring gaps had lined up with each other, any ideas why? i've not had any issues since reassembly but not something i want to happen if possible. I used to run Jun cosworth pistons and never had any issues, but since my bore is bigger than 87mm i cant use the jun ones anymore :D
coming along nicely.
wats your opinions on the spool rods paul?
Spool rods are manufactured by SCAT in america. SCAT have quite a good reputation as a reasonable quality product and are good value for money. In my opinion they are on par with Eagle and other rods in that price range.
Hi Paul - Just to clarify. Spool rods arent made by Scat or by the company that makes Scat rods or Eagle rods.
Not being picky - I just want that clarification made.
i think you need to clarify where they are made then...why do they use SCAT branded rod bolts??
I was more than happy to think they were made by SCAT as they have been making quality rods in USA for over 45 years and have an excellent reputation.
On your website you even use the same spiel as SCAT on your website "High tensile 4340 forged steel" "doweled cap for precision alignment" etc
Edited by DiRTgarage
When I bring the rods in they do not come with bolts. So I have to source the bolts here in Aus. I was buying bolts from Rocket for a while but they kept running out of the std ARP bolts and would supply me with the ARP 2000 bolts with SCAT on them - like you have there.
I now buy my bolts from Quantum here in Bris as they get them in from the US for me in quantity.
You can talk to Ryan at Rocket or Jason at Quantum to confirm.
All my rods now have ARP 2000 bolts with no SCAT on them.
Cheers
Edited by Spoolup
Scat are made in China, it is common knowledge now.
The price alone reflects where they are made.
Whether Spool or Scat are made in Taiwan , China , India , USA or Aus etc is really irrelevant. As the steel in SPOOL rods is 4340 ( had it tested several times ) the tolerances are perfect, the rod bolts are ARP and the quality is exceptional.
There are plenty of cars making power with SPOOL rods ( and the like ) and there are numerous workshops who recommend them ( talk to Mercury Motorsport, Proengines, Harris Engines, 6Boost etc ). Fitzpatrick Speedworks has a RB25 making 460 rwkw with those same SPOOL RB25 rods you have.
Ill email Scat in the US with a link to this thread. They can confirm or deny what you claim.
No doubt about the quality of the product you are selling as even the trained eye cannot pick the difference between the Spool and the Scat product. They were perfectly balanced and tolerances were exact when checked.
Thanks Paul, Im happy you like them.
I will post up some pics soon of the differences between SPOOL rods and Scat rods.
Cheers
cool...are you by any chance doing stroker cranks for anything other than RB30?
you will probably find that these rods are the same as electronics, the cheap and nasty stuff and the top of the range high quality stuff is quite possibly made by the same ppl, but some items are built to a price and others are built to a quality.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
