Nissans from 1:30 onwards :D
First run we had ice on the plenum and the HKS bellmouth. Then removed the bellmouth and ice for comparison, as you can see made alot of difference. So now a water to air intercooler is on the cards.
Thanks to Mamoon for the clip!
I have heard and seen mixed results with WM.
But i have seen 2 cars with water to air coolers on the dyno and the results are amazing.
Another car i saw on the weekend had a box made around one of the cooler pipes and you drop ice or dry ice through a pipe next to the washer bottle.This car has made close to 600awkw.
do u have any pics of this setup?
i couldn't imagine the ice would last long, how often would u need to top it up on a hot day (or is it just for dyno runs)?
No pics of it, normal ice and water is used for dyno and drag. Dry ice is used for the street as it lasts longer.
the ice box would be for dyno runs/drags, if its just plain water to air it could be used all the time, what intercooler do you have at the moment dave? 100mm thick core?
Its a china spec 76mm one which ill be throwing in the bin very soon.
still got white wheels eh...?
not long til you're dating dudes now.
So last night wasnt a date?
Lol
Dave those vids of your car are pornographic! The way it sounds and just keeps climbing in power and revs is unreal. Love it!
It was too loud for the camera hence all the distortion, in the flesh it sounds like an F1 car :P
Thats probably whats holding it back, stick a 100mm core in there. Everyone i have spoken to has said you need a thick intercooler if you want to push 400+ from the 35R
I wouldn't be blaming the cooler too much... It seems to be doing the job well it's just not big enough for the application!
I had a china spec 100mm with GTR style end tanks and it was freezing cold outlet temps running similar power at 24psi of a T04Z
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
